transfer of data
Hello,
I would like some help to pass values stored in a text file to a RAM card via a cable that I realized
int a[4];
int j=0;
int teste;
int info[14];
int z=0;
//pin d adresse
int L[13]={25,27,29,31,33,35,37,39,41,43,45,47,49};
int W[13]={7,6,5,4,3,2,14,15,16,17,18,19,20};
int wt=12;
int rmemd=9;
int rr=11;
int cp32=10;
int adresse=0;
int A[13];
int pret=9;
for(int i=0;i<13;i++)
pinMode(W[i],OUTPUT);
digitalWrite(W[i],LOW);
pinMode(wt,OUTPUT);
pinMode(rmemd,OUTPUT);
pinMode(cp32,OUTPUT);
pinMode(rr,OUTPUT);
digitalWrite(wt,LOW);
digitalWrite(rmemd,LOW);
digitalWrite(cp32,LOW);
digitalWrite(rr,HIGH);
while(teste!=1) //CODAGE ET SUPPRESSION DES PARASITES
if(Serial.available() > 0)
a[z]=Serial.read();
z++;
if(z==4)
if(a[0]==57 && a[1]==56 && a[2]==55 && a[3]==54)
teste=1;
z=0;
if(teste == 1)
info[j]=Serial.read();//LECTURE DE DONNEES
if(info[j]==50)
j=0;
if(info[j]==49)
info[j]=1;
if(info[j]==48)
info[j]=0;
if(j==13)
digitalWrite(cp32,HIGH);
digitalWrite(rr,LOW);
digitalWrite(rmemd,HIGH);
for(int i=0;i<13;i++) //@ d emission
A[i]=bitRead(adresse,i);
digitalWrite(L[12-i],A[i]);
for(int c=1;c<14;c++)
digitalWrite(W[c-1],info[c]);
digitalWrite(wt,HIGH);
Serial.print(pret);
j=0;
adresse++;
j++;
and the transfer operation is not performed
thank you for help
Please auto format your sketch and add comments.
Before posting code, it's a good idea to use the auto-format tool in the IDE to make it more legible.
What's the problem? Where's the schematic?
Why not get rid of A[] completely, and re-order L[], so then this becomes simply
digitalWrite (L[i], bitRead(adresse,i));
the project is the realization of a program loader I have the code loaded as a .txt file and I used processing that can transfer the frimware and the program through the USB cable.
int a[4];
int j=0;
int teste;
int info[14];
int z=0;
//pin d adresse
// pin configurer en sortie
//pin d ecriture
int wt=12;
// readmemory
int rmemd=9;
//read restore
int rr=11;
//clocke pulse
int cp32=10;
int adresse=0;
int A[13];
int pret=9;
pinMode(wt,OUTPUT);
pinMode(rr,OUTPUT);
a[z]=Serial.read();
z++;
if(z==4)
// verification de void keyPressed() deja definit dans le code processing pour la securité
teste=1;
z=0;
if(teste == 1)
if(info[j]==50)
j=0;//adaptation au niveau LOW des pins
if(info[j]==49)
info[j]=1;//adaptation au niveau HIGH des pins
if(info[j]==48)
info[j]=0;
if(j==13)
for(int i=0;i<13;i++) //adresse  d emission
Serial.print(pret);
j=0;
adresse++;
j++;
