transfer tag no. to mysql database
Hi all!!! I am having tough time to transfer my RFID tag no. to mysql database. When I compile the given code server gets connected so and prints the rfid no. and also says data sent to server but when I open my php file (also mysql) there is no data stored. What am I doing wrong!! P.s sorry for my bad english
#include <Ethernet.h>
#include <SPI.h>
#include <Client.h>
#include<SoftwareSerial.h>
SoftwareSerial RFID(2,3);
int i;
int rfid;
char newtag[14];// = {2,49,51,48,48,57,69,66,48,51,57,48,52,3};
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte subnet[] = {255,255,255,0};
//IPAddress gateway(192,168,1,1);
//IPAddress DBserver(192, 168, 1, 2);
IPAddress server(192,168,1,7);
//char server[] = "localhost/te";
IPAddress ip(192,168,1,2);
EthernetClient client;
  RFID.begin(9600);
  delay (1000);
  Serial.print("*********Initializing Ethernet*********\n");
  if (Ethernet.begin(mac) == 0) {
      Serial.println("Failed to configure Ethernet using DHCP");
      Ethernet.begin(mac, ip);
  //Ethernet.begin(mac, server, gateway);
  Serial.println("connecting...");
  Serial.print("IP Address:");
  Serial.println(Ethernet.localIP());
  Serial.print("Subnet Mask:");
  Serial.println(Ethernet.subnetMask());
  Serial.print("Default Gateway IP:");
  Serial.println(Ethernet.gatewayIP());
  Serial.print("DNS Server IP:");
  Serial.println(Ethernet.dnsServerIP());
 // while(1){
    if (client.connect(server, 80))
          Serial.print("Connected to server:");
   while(1)
     if (RFID.available() > 0)
      Serial.println("reading rfid tags");
      delay(100);
      for (i=0; i < 14; i++)
        rfid = RFID.read();
        newtag[i]=rfid;
      RFID.flush();
      Serial.print("rfid tag no:");
      Serial.print(newtag);
      Serial.println("Sending to Server...");
     client.println("GET 192.168.1.7/te/add_data.php?sensor=2323 HTTP/1.1");
    client.print(newtag);
    client.println(" HTTP/1.1");
      client.println("Host: 192.168.1.7/te/");
      client.println("User-Agent: Arduino");
      client.println("Accept: text/html");
      Serial.println("data sent to server");
        Serial.println("Cannot connect to Server");
and my php code is
<?php
    // Start MySQL Connection
    include('dbconnect.php');
<html>
<head>
    <title> Log</title>
    <style type="text/css">
        .table_titles, .table_cells_odd, .table_cells_even {
                padding-right: 20px;
                padding-left: 20px;
                color: #000;
        .table_titles {
            color: #FFF;
            background-color: #666;
        .table_cells_odd {
            background-color: #CCC;
        .table_cells_even {
            background-color: #FAFAFA;
        table {
            border: 2px solid #333;
        body { font-family: "Trebuchet MS", Arial; }
    </style>
</head>
    <body>
        <h1>Arduino  Log</h1>
    <table border="0" cellspacing="0" cellpadding="4">
      <tr>
            <td class="table_titles">ID</td>
            <td class="table_titles">Date and Time</td>
            <td class="table_titles">RFID tag</td>
          </tr>
<?php
    // Retrieve all records and display them
    $result = mysql_query("SELECT * FROM FYP ORDER BY id ASC");
    // Used for row color toggle
    $oddrow = true;
    // process every record
    while( $row = mysql_fetch_array($result) )
        if ($oddrow)
            $css_class=' class="table_cells_odd"';
            $css_class=' class="table_cells_even"';
        $oddrow = !$oddrow;
        echo '<tr>';
        echo '   <td'.$css_class.'>'.$row["id"].'</td>';
        echo '   <td'.$css_class.'>'.$row["event"].'</td>';
        echo '   <td'.$css_class.'>'.$row["tag"].'</td>';
        echo '</tr>';
    </table>
    </body>
</html>
      delay(100);
        rfid = RFID.read();
If there is one byte available to read, it is NOT okay to read 14 bytes. Never has been; never will be.
The server name (or IP address) is NOT part of the GET request.
The GET request ended with the HTTP/1.1 on the first line. The rest of that made a resounding thump in the bit bucket.
Nothing in your PHP script WRITES to the database. There is ONLY a read.
