Hello!
Maybe some of you have seen my previous messages about the HM-10 module.
I'm trying to transfer the temperature readings of my lm35 from the serial monitor to the screen on my iPhone, using "serial" app.
int val1;
int tempPin1 = A0;
char c = ' ';
char b = ' ';
Serial1.begin(9600);
val1 = analogRead(tempPin1);
int C1 = ( val1/1024.0)*500;
if (Serial1.available())
c = Serial1.read();
Serial.write(c);
c = ' ';
//Serial.print("TEMPRATURE C1 = ");
Serial.print(C1);
//Serial.print("*C");
if (Serial.available())
b = Serial.read();
Serial1.print(b);
b = ' ';
when i type on my app some Letter or number i receive it on my serial monitor, lm35's readings appears on the serial monitor but i don't see it on my app screen but when i type some Letter or number in the serial monitor i see it on my app screen but don't see the temperature readings!
maybe you can help me please.
thanks you very much
Liz0905:
It doesn't sound like a good idea, and probably not what you are really trying to do. IF you have succeeded in sending your LM35 data to the serial monitor, all you need do is connect bluetooth to hardware serial, pins 0,1. No further code required, i.e., in pseudo-code
loop(){
receive data from sensor;
Serial.print(data);
That's all. Serial monitor is not involved.
Nick_Pyner:
loop(){
Serial.print(data);
I'm really glad to hear that - for more than one reason.
I'm a bit of a fan of bluetooth and I have a couple of HM-10s, but I have never actually used them, indeed I studiously avoid BLE as I think it is more trouble than it is worth, and I know nothing at all about IOS.
In the light of your experience, I reckon it is now time to re-think the former, and also be less dismissive about using IOS. I have produced get-you-started notes on using HC-0x bluetooth which some people have found useful, and now I should update them with some comment on HM-10.
So...
what IOS phone app are you using specifically?
Is it just a plain vanilla terminal?
Have you tried any other apps?
Exactly which bluetooth module are you using?
Which Arduino?
and you really were able to do exactly what I said - connect bluetooth to serial port, go serial.print, and get exactly what you want?
You are not the first to successfully use Bluetooth>IOS for datalogging, but you are only the second that I actually know of, and I lost contact with the other guy before I could confirm exactly what was going on.
So, your contribution could be important, and I want to raise it with others who are more familiar with HM-10.
