I am trying to set up a CAN bridge between 2 different pieces of equipment. The data only needs to flow one way and is only related to one measurement.
I have set up the CAN bridge sketch but am stuck on how to transfer the data over.
The received data typically is;
Standard ID: 0x351 DLC: 8 Data: 0x10 0x02 0x72 0x01 0x72 0x01 0xC2 0x01
And that would need to be sent as;
CAN0.sendMsgBuf(0x05044000, 1, 8, "value");
Where “value” is 0x29, 0x15, 0x00, 0x10, 0x02
Any help would be gratefully received.
// CAN Bridge
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
unsigned char login[][8] = {
{0x16, 0x36, 0x71, 0x07, 0x03, 0x76, 0x00, 0x00},
{0x18, 0x10, 0x50, 0x01, 0x76, 0x09, 0x00, 0x00},
{0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0},
{0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0, 0x0}}; //The serial numbers are unique for each PS and must be set for your units
byte txBuf0[] = {66,55,66,55,66,55,66,55};
byte txBuf1[] = {55,66,55,66,55,66,55,66};
char msgString[128]; // Array to store serial string
char msgStringV1[128]; // Array to store serial string Volts
char msgStringV2[128];
char msgStringI1[128]; // Array to store serial string Amps
char msgStringI2[128];
#define CAN0_INT 3 // Set INT to pin 3 ELTEK
#define CAN1_INT 2 // Set INT to pin 2 PYLONTECH
MCP_CAN CAN0(9); // CAN0 interface usins CS on digital pin 9 ELTEK
MCP_CAN CAN1(10); // CAN1 interface using CS on digital pin 10 PYLONTECH
// init CAN0 bus, baudrate: 125k@8MHz ELTEK
if(CAN0.begin(MCP_ANY, CAN_500KBPS, MCP_8MHZ) == CAN_OK)
Serial.print("CAN 0 ELTEK: Init OK!\r\n");
CAN0.setMode(MCP_NORMAL);
Serial.println("Error Initializing MCP2515..CAN 0 Eltek");
// init CAN1 bus, baudrate: 500k@16MHz PYLONTECH
if(CAN1.begin(MCP_ANY, CAN_500KBPS, MCP_16MHZ) == CAN_OK)
Serial.print("CAN 1 PYLON: Init OK!\r\n");
CAN1.setMode(MCP_LISTENONLY);
Serial.println("Error Initializing MCP2515..CAN 1 Pylon");
CAN0.enOneShotTX();
SPI.setClockDivider(SPI_CLOCK_DIV2); // Set SPI to run at 8MHz (16MHz / 2 = 8 MHz)
CAN0.sendMsgBuf(0x1000000, 1, 8, txBuf0);
//CAN1.sendMsgBuf(0x1000001, 1, 8, txBuf1);
if(!digitalRead(2)) // If pin 2 is low, read CAN1 receive buffer PYLONTECH
CAN1.readMsgBuf(&rxId, &len, rxBuf); // Read data: len = data length, buf = data byte(s)
if(rxId == 0x351 || rxId == 0x359 || rxId == 0x355 || rxId == 0x356 || rxId == 0x35A || rxId == 0x35B || rxId == 0x35C || rxId == 0x35E || rxId == 0x35F || rxId == 0x00F || rxId == 0x305 || rxId == 0x306) // rxId == 0x305 || rxId == 0x306 ||
if(rxId == 0x351)
if((rxId & 0x80000000) == 0x80000000) // Determine if ID is standard (11 bits) or extended (29 bits)
sprintf(msgString, "Extended ID: 0x%.8lX DLC: %1d Data:", (rxId & 0x1FFFFFFF), len);
sprintf(msgString, "Standard ID: 0x%.3lX DLC: %1d Data:", rxId, len);
Serial.print(msgString);
if((rxId & 0x40000000) == 0x40000000) // Determine if message is a remote request frame.
sprintf(msgString, " REMOTE REQUEST FRAME");
for(byte i = 0; i<len; i++)
sprintf(msgString, " 0x%.2X", rxBuf[i]);
if(rxId == 0x351)
sprintf(msgStringV1, " 0x%.2X", rxBuf[0]);
sprintf(msgStringV2, " 0x%.2X", rxBuf[1]);
Serial.print ("Voltage setting, volts ");
Serial.print(msgStringV1);
Serial.println(msgStringV2);
CAN0.sendMsgBuf(0x05004804, 1, 8, login[1]); // Immediately send message out CAN0 interface ELTEK Login
delay (50);
CAN0.sendMsgBuf(0x05004808, 1, 8, login[2]); // Immediately send message out CAN0 interface ELTEK Login
delay (50);
CAN0.sendMsgBuf(0x0500480C, 1, 8, login[3]); // Immediately send message out CAN0 interface ELTEK Login
delay (50);
CAN0.sendMsgBuf(0x05044000, 1, 8, "value"); // Immediately send message out CAN0 interface ELTEK Volts
delay (50);
CAN0.sendMsgBuf(0x05084000, 1, 8, "value"); // Immediately send message out CAN0 interface ELTEK Volts
delay (50);
CAN0.sendMsgBuf(0x050C4000, 1, 8, "value"); // Immediately send message out CAN0 interface ELTEK Volts
delay (50);
sprintf(msgStringI1, " 0x%.2X", rxBuf[2]);
sprintf(msgStringI2, " 0x%.2X", rxBuf[3]);
Serial.print ("Current setting, amps ");
Serial.print(msgStringI1);
Serial.println(msgStringI2);
//CAN0.sendMsgBuf(0x1000000, 1, 8, txBuf0);
//CAN0.sendMsgBuf(rxId, 1, len, rxBuf); // Immediately send message out CAN0 interface ELTEK Current
END FILE
