I need help transferring data to the Hatire Plugin from serial to serial1(on Mega 2560, connecting to RX1 and TX1) via a Bluetooth HC-05 module. The data seem to be transmitting via the Bluetooth module, since no USB cable were connected to the Mega2560. (Quite honestly, I am not sure what is been transmitted)
//MinIMU9AHRS Tab
//Variable declaration/assignment
typedef struct {
int16_t Begin ; // 2 Debut
uint16_t Cpt ; // 2 Compteur trame or Code
float gyro[3]; // 12 [Y, P, R] gyro
float acc[3]; // 12 [x, y, z] Acc
int16_t End ; // 2 Fin
} hat;
_hat hat;
// header frame...
hat.Begin=0xAAAA;
// Frame Number or Error code
hat.Cpt=0;
// footer frame hat.
End=0x5555;
//Placed in the Output tab portion
//This is the portion where I would like to send to serial1
void printdata(void)
hat.gyro[0] = ToDeg(roll);
hat.gyro[1] = ToDeg(pitch);
hat.gyro[2] = ToDeg(yaw);
// Send Trame to HATIRE PC
Serial.write((byte*)&hat,30);
// inc frame cpt
hat.Cpt++;
if (hat.Cpt>1000) {
hat.Cpt=0;;
Kindly see the the following link from the original creator/Coder
https://sourceforge.net/p/facetracknoir/discussion/iht/thread/eced1cb2/?limit=25&page=2#2368
Regards and thanks
MinIMU9AHRS.ino (7.28 KB)
Output.ino (3.01 KB)
