New to this forum and this is first post. I'm trying to send data from 14 I/O pins on one board (Arduino UNO or NANO, most likely) via BLE (HC-05) to a second board with an HC-05. The data sent from one board's pins should correspond to the second board's pins when received (e.g., output data from pin 1 on the first board is sent and registered as input data at pin 1 on the second board). It's like creating a wireless serial cable, if that makes sense, and should function as if a 14-cable serial cable was physically connected between the boards.
Good question! I plan to connect the HC-05 to pins 0 and 1 for serial comms, while Digital pins 2 through 13 and Analog pins 0 and 1 (for a total of 14) will be connected to individual wires (which will be connected to a card reader on one board and an actual card with 14 pin pads on the second board). The analog pins will be changed to digital read mode and I plan to change every I/O pin to be both input and output for send/receive functionality. Just not sure how the BLE modules will interpret the data form all 14 pins at once.
My bad...I'm used to writing BLE instead of just BT. Thanks for the link; I hadn't seen that thread but will read through it vigorously and thoroughly!
At the expense of a little more processing you could transfer 14 bits of digital data in 2 bytes with 2 bits to spare. Even if you add a start and ends marker that requires just 4 bytes rather than perhaps 16
