pout 68tjs: voici la recopie complète de la console après tentative de téléverser blink:
j'ai dû effacer le début car trop de caractères
Arduino : 1.8.1 (Windows 10), Carte : "Arduino/Genuino Uno"
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\sketch\Blink.ino.cpp" -o "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\preproc\ctags_target_for_gcc_minus_e.cpp"
Compilation du croquis...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\sketch\Blink.ino.cpp" -o "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Utilisation du fichier déjà compilé : C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\core\abi.cpp.o
Utilisation du fichier déjà compilé : C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\core\main.cpp.o
Utilisation du fichier déjà compilé : C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\core\new.cpp.o
Utilisation du fichier déjà compilé : C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\core\core.a
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644/Blink.ino.elf" "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644\sketch\Blink.ino.cpp.o" "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644/core\core.a" "-LC:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644/Blink.ino.elf" "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644/Blink.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644/Blink.ino.elf" "C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644/Blink.ino.hex"
Le croquis utilise 928 octets (2%) de l'espace de stockage de programmes. Le maximum est de 32256 octets.
Les variables globales utilisent 9 octets (0%) de mémoire dynamique, ce qui laisse 2039 octets pour les variables locales. Le maximum est de 2048 octets.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM3 -b19200 -Uflash:w:C:\Users\JEAN_C~1\AppData\Local\Temp\arduino_build_400644/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x00ff00
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
avrdude done. Thank you.
Mauvais microcontrôleur trouvé. Avez-vous sélectionné la bonne carte dans le menu Outils > Type de carte ?
