Transform void loop() into timer with intterrupts
Hello there guys. So, i have this code:
//declararea butoanelor
const int b1 = 2;
const int b2 = 3;
const int b3 = 4;
const int b4 = 5;
const int b5 = 11; //buton resetare conexiune
//declararea ledurilor
int ledTV = 9;
int ledDVD = 8;
int ledCD = 7;
int ledRAD = 6;
int ledpv = 10; //program si volum
  //declararea ledurilor ca si OUTPUT-uri
  pinMode(ledTV, OUTPUT);
  pinMode(ledDVD, OUTPUT);
  pinMode(ledCD, OUTPUT);
  pinMode(ledRAD, OUTPUT);
  pinMode(ledpv, OUTPUT);
  //declararea butoanelor ca si INPUT-uri
  pinMode(b1, INPUT);
  pinMode(b2, INPUT);
  pinMode(b3, INPUT);
  pinMode(b4, INPUT);
  pinMode(b5, INPUT);
int bs1 = 0;
int bs2 = 0;
int bs3 = 0;
int bs4 = 0;
int bs5 = 0;
byte lastButton1Value = LOW;
byte lastButton2Value = LOW;
byte lastButton3Value = LOW;
byte lastButton4Value = LOW;
int blinkRepeats;
int seconds;
  read_bs();
  int device = bs1 + bs2*2 + bs3*4 + bs4*8;
  int exitd;
  switch(device)
    case 1:
      digitalWrite(ledRAD, HIGH);
      exitd=0;
      while(exitd<1)
        blinkpv(ledpv, blinkRepeats, 1000);
        if(digitalRead(b5)==HIGH)
          exitd++;
    case 2:
      digitalWrite(ledCD, HIGH);
      reset_bs();
      exitd=0;
      while(exitd<1)
        blinkpv(ledpv, blinkRepeats, 2000);
          exitd++;
    case 4:
      digitalWrite(ledDVD, HIGH);
      reset_bs();
      exitd=0;
      while(exitd<1)
        blinkpv(ledpv, blinkRepeats, 3000);
          exitd++;
    case 8:
      digitalWrite(ledTV, HIGH);
      reset_bs();
      exitd=0;
      while(exitd<1)
        blinkpv(ledpv, blinkRepeats, 4000);
          exitd++;
  turnOff();
void read_bs()
  bs1=digitalRead(b1);
  bs2=digitalRead(b2);
  bs3=digitalRead(b3);
  bs4=digitalRead(b4);
void reset_bs()
  bs1=bs2=bs3=bs4=0;
void turnOff()
  static int lastbs5 = LOW;
  bs5=digitalRead(b5);
  if((bs5==HIGH)&&(bs5!=lastbs5))
    digitalWrite(ledTV, LOW);
    digitalWrite(ledDVD, LOW);
    digitalWrite(ledRAD, LOW);
    digitalWrite(ledCD, LOW);
    digitalWrite(ledpv, LOW);
  lastbs5=bs5;
void blinkpv(int led, int &count, int seconds)
  byte button1Value = digitalRead(b1);
  byte button2Value = digitalRead(b2);
  byte button3Value = digitalRead(b3);
  byte button4Value = digitalRead(b4);
  if (button1Value == LOW && lastButton1Value == HIGH)
    blinkRepeats = 1;
    if (button2Value == LOW && lastButton2Value == HIGH)
      blinkRepeats = 2;
        if (button3Value == LOW && lastButton3Value == HIGH)
          blinkRepeats = 3;
          if (button4Value == LOW && lastButton4Value == HIGH)
            blinkRepeats = 4;
  lastButton1Value = button1Value;
  lastButton2Value = button2Value;
  lastButton3Value = button3Value;
  lastButton4Value = button4Value;
  static unsigned long lastMillis = 0;
  static int interval = 1;
  static int lastCount = 0;
  if (count > lastCount)
    interval = seconds / 2 / count;
    lastMillis = millis();
  if (count <= 0)
    count = 0;
    return;
  if (millis() - lastMillis > interval)
    if (digitalRead(led))
      count--;
    digitalWrite(led, !digitalRead(led));
    lastMillis += interval;
  lastCount = count;
Basically, this code is used to connect to four devices, using 4 buttons. After connecting to one device, the same 4 buttons are used to light a 5th led in different ways.
The problem is that I am not allowed to use void loop()… How can i integrate a timer with interrupts that allows me to run the program?!
Thank you very much!
Xeyow: The problem is that I am not allowed to use void loop()...
Why not?
Because the teacher wants to use interrupts.
I think that all the code in the void loop () must be integrated into a timer... how can i do that? i know nothing about timers...
You realize these are different variables, right?
[quote author=Nick Gammon link=msg=2561064 date=1452581403]
You realize these are different variables, right? [/quote]
yes... whats wrong with that? ive used them to be able to select the number of blinks per interval of seconds....
I want to make the void loop () empty, but the code that was in it, the switch case and other stuff, to be integrated into a timer...
try this:
http://lmgtfy.com/?q=arduino+timers
arduinodlb: try this:
You are not helping me. First of all: i have never used interrupts on arduino... i do not understand how they work. help me and provide me a sketch or something...
Read this discussion and examples: http://www.gammon.com.au/interrupts .
I am being a great help to you telling you that you will have to learn how to use a search engine like google.
You are very welcome if you have specific questions or problems you need help with, but you do not tell people that they "provide you a sketch or something". Especially not if you're doing homework.
const int b1 = 2;
const int b2 = 3;
const int b3 = 4;
const int b4 = 5;
int ledTV = 9;
int ledDVD = 8;
int ledCD = 7;
int ledRAD = 6;
int blinkRepeats;
int seconds;
  noInterrupts();
  pinMode(b1, INPUT);
  pinMode(b2, INPUT);
  pinMode(b3, INPUT);
  pinMode(b4, INPUT);
  pinMode(b5, INPUT);
  TCCR1A = 0;
  TCCR1B = 0;
  TCNT1 = 0;
  OCR1A = 312;
  TCCR1B |= (1<<WGM12);
  TCCR1B |= (1<<CS10);
  TIMSK1 |= (1<<OCIE1A);
  interrupts();
  //Serial.begin(9600);
ISR (TIMER1_COMPA_vect)
  int Q = 1;
  switch (Q)
    case 1:
      if(digitalRead(b1)==HIGH)
        Q=2;
          if(digitalRead(b2)==HIGH)
            Q=3;
            if(digitalRead(b3)==HIGH)
              Q=4;
              if(digitalRead(b4)==HIGH)
                Q=5;
    case 2:
        Q=1;
      blinkpv(ledpv, 0, 4000);
    case 3:
        Q=1;
    case 4:
        Q=1;
    case 5:
        Q=1;
void loop() {}
void blinkpv(int led, int count, int seconds)
  int blinkrepeats;
    blinkRepeats = 1;
      blinkRepeats = 2;
          blinkRepeats = 3;
            blinkRepeats = 4;
  if (count <= 0)
    count = 0;
    return;
      count--;
  lastCount = count;
Is this correct?! I do not have the breadboard / leds / buttons… Do you think it will work?!
  int Q = 1;
  switch (Q)
    case 1:
Every time the ISR is called then Q will be set to 1 and case 1 will be executed. How are the other cases ever going to be executed ?
Xeyow:
You are not helping me. First of all: i have never used interrupts on arduino… i do not understand how they work. help me and provide me a sketch or something…
Actually, I am helping you. The first link that is displayed EXPLAINS in great detail the TIMER1 system on Arduinos, and how to use the interrupts associated with timers. Read it. And learn how to use google.
Don’t be lazy. Do the research and learn. That is the point of your homework. We will not do your homework for you, but we will help you when you get stuck. But, you have to put in some effort yourself.
Xeyow: i do not understand how they work. help me and provide me a sketch or something...
Do my homework for me? Is that it?
UKHeliBob: ``` ISR (TIMER1_COMPA_vect) {   int Q = 1;
  switch (Q)   {     case 1:
Yup... i think int Q=1, should be declared global, right?!
Xeyow: Yup... i think int Q=1, should be declared global, right?!
or you could declare it inside your function as static. It would have the same effect as declaring it global, but only things executing inside your function could access it (local visibility).
  static int Q = 1;
  Q++;
  Serial.print(Q); // would show Q increasing each time the ISR is executed
i will try to upload the code on my arduino and see if the button/leds are working. Hope it works.
arduinodlb: or you could declare it inside your function as static. It would have the same effect as declaring it global, but only things executing inside your function could access it (local visibility).
  static int Q = 1;
 Q++;  Serial.print(Q); // would show Q increasing each time the ISQ is executed ... }
Don't do serial prints inside an ISR.
arduinodlb God Member Posts: 897
Don't even suggest it.
I didn't intend that he should run that code. I was merely trying to demonstrate what would happen to Q, but I take your point.
Oke, so my code works untill the point of blinkpv function. Lets say Q=1; I press button 1 => q=2. i turn led2 ON, but the function blinkpv, doesnt work…
