Transform .wav file to vector
I have found this code here:
code down on the page
which I tested it, but because it is a sine, I cannot understand if the DAC wokrs. So, because I do not have SD card interface, is there any program/way to trasform a .wav file (it is small) to a vector so that I insert it on the code above and upload to the Arduino?
(deleted)
If the .wav file is short maybe using Serial Monitor or Serial Plotter would help?
spycatcher2k:
Do you know what a vector is? If you did, you will see how this question is nonsense.
Explain WHAT you are trying to achieve.
This is part of the source code, of the Sparkfun, of the link I posted above:
int sintab2[512] =
2048, 2073, 2098, 2123, 2148, 2174, 2199, 2224,
2249, 2274, 2299, 2324, 2349, 2373, 2398, 2423,
2448, 2472, 2497, 2521, 2546, 2570, 2594, 2618,
2643, 2667, 2690, 2714, 2738, 2762, 2785, 2808,
2832, 2855, 2878, 2901, 2924, 2946, 2969, 2991,
3013, 3036, 3057, 3079, 3101, 3122, 3144, 3165,
3186, 3207, 3227, 3248, 3268, 3288, 3308, 3328,
3347, 3367, 3386, 3405, 3423, 3442, 3460, 3478,
3496, 3514, 3531, 3548, 3565, 3582, 3599, 3615,
3631, 3647, 3663, 3678, 3693, 3708, 3722, 3737,
3751, 3765, 3778, 3792, 3805, 3817, 3830, 3842,
3854, 3866, 3877, 3888, 3899, 3910, 3920, 3930,
3940, 3950, 3959, 3968, 3976, 3985, 3993, 4000,
4008, 4015, 4022, 4028, 4035, 4041, 4046, 4052,
4057, 4061, 4066, 4070, 4074, 4077, 4081, 4084,
4086, 4088, 4090, 4092, 4094, 4095, 4095, 4095,
4095, 4095, 4095, 4095, 4094, 4092, 4090, 4088,
4086, 4084, 4081, 4077, 4074, 4070, 4066, 4061,
4057, 4052, 4046, 4041, 4035, 4028, 4022, 4015,
4008, 4000, 3993, 3985, 3976, 3968, 3959, 3950,
3940, 3930, 3920, 3910, 3899, 3888, 3877, 3866,
3854, 3842, 3830, 3817, 3805, 3792, 3778, 3765,
3751, 3737, 3722, 3708, 3693, 3678, 3663, 3647,
3631, 3615, 3599, 3582, 3565, 3548, 3531, 3514,
3496, 3478, 3460, 3442, 3423, 3405, 3386, 3367,
3347, 3328, 3308, 3288, 3268, 3248, 3227, 3207,
3186, 3165, 3144, 3122, 3101, 3079, 3057, 3036,
3013, 2991, 2969, 2946, 2924, 2901, 2878, 2855,
2832, 2808, 2785, 2762, 2738, 2714, 2690, 2667,
2643, 2618, 2594, 2570, 2546, 2521, 2497, 2472,
2448, 2423, 2398, 2373, 2349, 2324, 2299, 2274,
2249, 2224, 2199, 2174, 2148, 2123, 2098, 2073,
2048, 2023, 1998, 1973, 1948, 1922, 1897, 1872,
1847, 1822, 1797, 1772, 1747, 1723, 1698, 1673,
1648, 1624, 1599, 1575, 1550, 1526, 1502, 1478,
1453, 1429, 1406, 1382, 1358, 1334, 1311, 1288,
1264, 1241, 1218, 1195, 1172, 1150, 1127, 1105,
1083, 1060, 1039, 1017, 995, 974, 952, 931,
910, 889, 869, 848, 828, 808, 788, 768,
749, 729, 710, 691, 673, 654, 636, 618,
600, 582, 565, 548, 531, 514, 497, 481,
465, 449, 433, 418, 403, 388, 374, 359,
345, 331, 318, 304, 291, 279, 266, 254,
242, 230, 219, 208, 197, 186, 176, 166,
156, 146, 137, 128, 120, 111, 103, 96,
88, 81, 74, 68, 61, 55, 50, 44,
39, 35, 30, 26, 22, 19, 15, 12,
10, 8, 6, 4, 2, 1, 1, 0,
0, 0, 1, 1, 2, 4, 6, 8,
10, 12, 15, 19, 22, 26, 30, 35,
39, 44, 50, 55, 61, 68, 74, 81,
88, 96, 103, 111, 120, 128, 137, 146,
156, 166, 176, 186, 197, 208, 219, 230,
242, 254, 266, 279, 291, 304, 318, 331,
345, 359, 374, 388, 403, 418, 433, 449,
465, 481, 497, 514, 531, 548, 565, 582,
600, 618, 636, 654, 673, 691, 710, 729,
749, 768, 788, 808, 828, 848, 869, 889,
910, 931, 952, 974, 995, 1017, 1039, 1060,
1083, 1105, 1127, 1150, 1172, 1195, 1218, 1241,
1264, 1288, 1311, 1334, 1358, 1382, 1406, 1429,
1453, 1478, 1502, 1526, 1550, 1575, 1599, 1624,
1648, 1673, 1698, 1723, 1747, 1772, 1797, 1822,
1847, 1872, 1897, 1922, 1948, 1973, 1998, 2023
It is a sine. Instead of a sine I want to put part of a .wav file (transformed to a vector), in order to test my DAC…
Can someone help?
int sintab2[512] we call Array....
Yes, my mistake… array!!! :slight_smile:
Simply replace the 512 values in the vector (or array) definition for sintab2[] with 512 values from the .wav file.
Yes, ok,... how do I do this...?
alex5678:
Matlab perhaps… such as…
click here…
From 16-bit resolution, you could then scale to 12-bit resolution.
and… extra reference…
click here…
A sine wave is a fine test for a DAC.
jremington: A sine wave is a fine test for a DAC.
If you own an osciloscope yes, otherwise you cannot here something varying...
Something more, I used audioread on matlab in order to read the .wav file, but I got values like this: -0.1688, 0.1923, 0.7965, how do I transform them to 12-bit positive integers?
Multiply by a suitable fugure, 1000(?) and add an offset to get above zero.
If you can hear a WAV file (if you figure out how to encode it) then there's no reason that you can't hear a sine wave as long as it is in the audible range.
Pete
alex5678: Yes, ok,... how do I do this...?
You either type it in by hand, or write a program in a language like Processing to print out the bytes in the WAV file like your code needs and then copy and paste.
That array is too big for most Arduinos so you will have to put it into program memory.
Code to do this is in my book https://www.apress.com/gb/book/9781484217207
Thank you!
Is it something I can find on the source code that this link provides?
If I manage to install SD card to the Arduino, again can I store the sound as integer values on an array?
Yes, sure data on an SD card will work. Just get the raw integers there.
Play the sine wave amplitudes back at a frequency you can hear.
Obviously, you need to do some more reading.
Yes all the code you need is in that link.
It is chapter 14.
