OP PLEASE STOP CROSS-POSTING.
This wastes time.
HazardsMind:
If your following the first link I gave you then, tip 41, should be fine. But looking at the data sheet, its made for high voltage applications. Kinda overkill for your project. You may just want to get some 2n3904 or 2n3906 NPN transistors from RadioShack, or simply a H-bridge DC Driver IC.
dude! i came from the store from the nearest city, i it is not available. they give me numbers of transistors and i picked 2n551 since its the nearest number from what you have given.
the question is do the 2n5551 can handle the 7v? i wried its data shit but i dont understand what it means
The 2n5551 is fine, the maximum voltage it can handle is 160 volts, so 7 volts should be nothing to it.
HazardsMind:
wow, what did you say? 160vots for that little tiny transistor? absolutely incredible offer.
the led or the load has no problem switching if its in the collectors pin but
when the led is in the emitter, the led will not light. no switching is done.
as well as the hbridge. it seems impossible to make it work. whats wrong with it? connections of pins are correct.
Double check your wiring, and make sure only one side of the H bridge is on at a time.
HazardsMind:
this half of the hbridge didnt also work. as the first transistor doesn't triggered since the load is in the emitter.
I don't think 3.5 volts is enough to drive that circuit. Try 6 or 9 volts, and 5v at the base.
That circuit will not work as it stands and may damage the lower transistor because there is no resistor to limit the base current. Put a 100 ohm resistor in series with the base of the upper transistor, and a 470 ohm resistor in series with the base of the lower transistor. Increase both the power supply voltage and the drive voltage to 5V. That will give you about 3V or 3.5V across the load.
dc42:
is this what your trying to express?
The resistors go the other way round (470 ohm to the lower transistor, 100 ohm to the upper transistor), and both the 1.5V and the 3.5V need to be increased to 5V if you want to feed about 3.5V to the motor.
Yes but swap the resistors around, and provide 5volts (not 1.5v) to the base and 6-9volts(not 3.5v) to the actual power source.
Edit: dc42 beat me to it.
dc42:
thanks for the help, but my problem is in the robots motor. it only has lower than 4v i think for its dc motor, and i want to amplify it to a bigger volts. and replacing its motor to a bigger motor,. 6v motor.
pls help me. read my past post for more info. thanks.
Can you show us a picture? What is this motor in, does it have its own housing, holding it in place. You might not be able to change it.
Post a picture, that way we will have a better understanding of what your trying to do.
HazardsMind:
Can you show us a picture? What is this motor in, does it have its own housing, holding it in place. You might not be able to change it.Post a picture, that way we will have a better understanding of what your trying to do.
i want to amplify the volts produced by the line follower to power its dc motor, since its to weak to carry my sla 7v battery so i will modify my dc motor to a bigger and stronger one,. the logic of hbridge is correct but the hbridge wont work at all.
the power source of the robot is also from the sla battery.
Those motors are going to require a lot of current, your best bet now would be to get a actually Hbridge board. http://item.mobileweb.ebay.com/viewitem?itemId=251080674810&index=1&nav=SEARCH&nid=83702557639
HazardsMind:
you know i cant, because im in the philippines, im in the part of the philippines where those items are not available.
i would travel far away to the capital manila to get those items.
is their any one that can help me using only basic transistors?
i think i will not found the answer any more. for ever. i am loosing my hope now =(
Can you get hold of DPDT relays (or SPDT relays)?
Use those instead of the H-bridge.
I think I've already suggested this.
jaylisto:
Hardly surprising - that battery is absurdly oversize for a 'bot that small. How many months were you hoping this thing would run between recharges?
How many transistors did you get, maybe you can double them up and make them into darlington pairs.
