transistor works but i am unable to amplify
So I am trying to make a basic circuit where an arduino pin controls a transistor, and that transistor is used to turn things on and off. I wired it up like so, and it works great -
Imgur
However, the real goal is to use the transistor to pull in external power, like a 9v battery or power from a wall adaptor. I pull the arduino 5v to LED wire, replace it with +9v to LED, and connect my 9v ground to the circuit ground -
Imgur
No dice! I realize the 9v may blow the LED but I was trying earlier with my relay, and again with multimeter leads plugged right in. What am I doing wrong?
I am trying to follow this circuit here, only replacing the DC motor, and skipping the diode + cap (also I tried with the diode in place earlier, removed it to simplify/debug) -
Imgur
Thanks for looking! I am lost.
See image below:
OH. MY. GOODNESS.
(hangs head)
Thank you so much.
