Transistor
All such gloves use resistive elements of some sort - normally NiChrome wire, but any power dissipating element would do .....
eg a Pentium processor.
NiCr is cheap and effective.
For temperature sensing a thermistor is the obvious device.
Allan
allanhurst: ... eg a Pentium processor.
Cool! You could recycle old, unwanted computers as hand warmers.
allanhurst: ... For temperature sensing a thermistor is the obvious device.
Wouldn't a device like a TMP36 (such as this one) be even simpler to use?
TMP36...
Sure,
There's a hundred ways to skin a cat.
I bought 100 10k thermistors for £1. Though I don't intend to control 50 pairs of gloves.
You don't need an arduino for this job - a simple bit of analog will do.
Ramp generator ( 555? ) , comparator , reference volts source.and power switch device
Allan
Of course you are correct - that would certainly be the most cost-efficient to build heated gloves. But that isn't the theme here. It seems our OP wants to make something DIY with parts on hand. And Arduino control has easy appeal. But with 50-250 watts of power inside an insulated glove, I wonder what it's actual use would be.
The ancient LM10, designed by Bob Widlar, would be ideal for this job.....
but I share your puzzlement over the application.
Any help.OP?
Allan
MarkT:
250W is crazily high and will burn you.
1W will do nothing.
So 10W is about right as a starting point for designing a warmer like this. Perhaps it should be 20W,
perhaps not, you need to experiment. Remember a lot of soldering irons use 40W or less…
I’m intrigued by the project and wanted to see what I could make and get a feel for what wattage a glove heater might need to be. I etched a heater from polyimide film using material that I requested for free from Dupont’s website:
The heater I made was this spiral thingie (see picture below) that I then cut up to be one long heater. It has a resistance of 3.5 ohms. It is just long enough to wrap around each of five fingers.
I’m powering it with an old weedeater battery that limits current to 1.5A. The battery is 20V so I’m using a buck converter to take it down to 6V.
To test I wore a thin cotton glove and then wrapped one finger with the heater and turned it on. I could feel it warm up quickly but didn’t get too hot. If I put this assembly inside of a winter glove I think it would work even better. At 9 watts it’s just right for my tastes.
A thought I had was to adhere the polyimide heater to the glove with thermal glue and then spray it with plasti-dip to give it a rubber coating and make it more water resistant. It would sort of be a hybrid of two different flexible heaters.
You heated glove prototype is much more efficient at heating the air than your hand. The outside of the heater coil should be well insulated thermally, and the power can then be dropped.
MarkT: You heated glove prototype is much more efficient at heating the air than your hand. The outside of the heater coil should be well insulated thermally, and the power can then be dropped.
Nice. I wonder how low I could go with power and still have sufficiently useful warming. I'll try putting it inside a good ski glove finger first and then maybe I'll try dipping or spraying with rubber.
I think you'll have to do some experimentation with a gloved hand in an icebox!
What's wrong with good ole' NiChrome wire?
Allan
Well nichrome wire isn't insulated so you'd need to arrange that, and its probably overkill (you aren't needing fairly constant resistance upto orange heat!)
Steel wire has a reasonable amount of resistance, is available insulated (for garden use like plant ties), and is cheap and tough. Stainless steel wire also.
