Transistor
Hello,
can i replace the 2n2222 transistor by ztx450 directly??
is the pinout the same exactly??
thanx
golf-2:
Hello,
thanx
You might have to take a look at the wiki site ... 2N2222 - Wikipedia
and see the pins for the various versions...
and look at this site.... to make sure the pins align with the particular version of 2n2222...
Since the packages are different (TO92 and e-line), in some sense the pinouts cannot be the same.
(ie the pads are differently placed on a pcb)
With transistors you can either check the datasheets or use a transistor or component tester (which
also checks if its working).
