"translateIR" was not declared in this scope
Hey everyone,
I’m having a strange issue with a int at the beginning of a loop not being declared, I put in globally and still had the same issues…
I’m basically having a thermocouple read a temp, display it, and have it turn on a relay if it drops below a certain temp.
The IR remote is suppose to be the input to my desired temp, and that’s the part of the code I am having issues with.
Not sure what to do at this point. Can anyone see any problems with this code? By itself, the IR code works just fine.
#include <IRremote.h>
#include "Adafruit_MAX31855.h"
#include <SPI.h>
#include <Wire.h>
#define MAXDO   3
#define MAXCS   4
#define MAXCLK  5
Adafruit_MAX31855 thermocouple(MAXCLK, MAXCS, MAXDO);
int RECV_PIN = 11;
int i = 0;
IRrecv irrecv(RECV_PIN);
decode_results results;
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x3F for an LCD with 16 columns and 2 rows
irrecv.enableIRIn(); // Start the receiver
lcd.init();                     // initialize the lcd
 lcd.setBacklight(HIGH);         // turn the LCD backlight on (HIGH is on, LOW is off)
   lcd.setCursor(0,0);             // go to column 0, row 0
      lcd.print("Set Temp:");    //Set Temprature by User
   lcd.setCursor(0,1);             // go to column 0, row 1
      lcd.print("Temprature:"); //Current Temprature
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  // If a key was pressed then do the following
  if (irrecv.decode(&results)) {
    int numPressed = translateIR();
    // Print it if its not the default value
    if (numPressed != 9999) {
      Serial.print(results.value, HEX);
      Serial.print('\t');
      Serial.println(numPressed);
if (numPressed > 200){
  double c = thermocouple.readCelsius();
  lcd.setCursor(12,1);
  lcd.print(c);
  lcd.println(thermocouple.readInternal());
   if (c < numPressed) {
   digitalWrite(12,LOW);}
   if (c > numPressed) {
   digitalWrite(12,HIGH);}
   irrecv.resume(); // Receive the next value
  int translateIR() {
  int key;
  switch (results.value) {
    case 0xFF6897: key = 0; break;
    case 0xFF30CF: key = 200; break;
    case 0xFF18E7: key = 220; break;
    case 0xFF7A85: key = 230; break;
    case 0xFF10EF: key = 240; break;
    case 0xFF38C7: key = 250; break;
    case 0xFF5AA5: key = 260; break;
    case 0xFF42BD: key = 270; break;
    case 0xFF4AB5: key = 280; break;
    case 0xFF52AD: key = 290; break;
    default: key = 9999;
  delay(100);
  return key;
Code,
like text,
is really hard to read when it wanders
all over the page.
Check your {} braces/
