Hello,
I am currently stuck with troubleshooting the transmission failure of my sensor node. It can work for several days fine until it reports a failure detected by the LMIC library and stops transmitting. I am using Arduino IDE, ATMEGA328P and an external interrupt to wake up my sensor node after a certain time interval.
For troubleshooting, I have logged the events using an SD card and noticed following error msg:
> Measurement done
> 23:40:18
> Sending uplink packet...
> FAILURE
The failure arises from the LMIC library and most likely this part:
> // start transmitter (buf=LMIC.frame, len=LMIC.dataLen)
> static void starttx () {
> ASSERT( (readReg(RegOpMode) & OPMODE_MASK) == OPMODE_SLEEP );
> if(getSf(LMIC.rps) == FSK) { // FSK modem
> txfsk();
> } else { // LoRa modem
> txlora();
> // the radio will go back to STANDBY mode as soon as the TX is finished
> // the corresponding IRQ will inform us about completion.
The assert function checks the statement and reports an error. How do you think shall I troubleshoot this problem?
I have thought about:
- editing the library to report no failures
- changing the code flow to allow
- best solution imo: add an if statement in the Arduino code to force sleep or restart the loop after detecting a failure.
Thank you!
