Transmitter Receiver Issue
Hi all
I have bought a simple pair of Transmitter Receiver.However using virtualWire library though my transmitter seems to work...my receiver(XY-MK-5v) does not receive any message and only prints "setup"...I have tried different libraries but yet its not working and when I use the code using no library,I can receive numbers of 0 or 400 roughly.I really dont know whats the reason.
I have to mention our final intention is to send simple characters like "A","B" etc...
Realy appreciate any help...
Follow is the code im using:
Transmitter:
#include <VirtualWire.h>
Serial.begin(9600); // Debugging only
Serial.println("setup");
// Initialise the IO and ISR
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2000); // Bits per sec
vw_set_tx_pin(7);
const char *msg = "hello";
Serial.println("hello");
digitalWrite(13, true); // Flash a light to show transmitting
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(13, false);
delay(200);
Receiver:
#define rfReceivePin A0
vw_rx_start(); // Start the receiver PLL running
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
digitalWrite(13, false); // Flash a light to show received good message
// Message with a good checksum received, dump it.
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
Serial.print(buf*, HEX);*
  • Serial.print(" ");*
  • Serial.println("");*
  • digitalWrite(13, true);*
http://www.airspayce.com/mikem/arduino/VirtualWire/
"END OF LIFE NOTICE
This VirtualWire library has now been superceded by the RadioHead library RadioHead: RadioHead Packet Radio library for embedded microprocessors RadioHead and its RH_ASK driver provides all the features supported by VirtualWire, and much more besides, including Reliable Datagrams, Addressing, Routing and Meshes. All the platforms that VirtualWire supported are also supported by RadioHead.
This library will no longer be maintained or updated, but we will continue to publish it for the benefit of the the community. Nevertheless we recommend upgrading to RadioHead where possible."
