Hello everyone!!!
I have 2 joysticks (joyL and joyR) to run 2 dc motors (motorL and motorR) individually. But only one dc motor are running (for joyL and motorL) and for the (joyR and motorR) produces this error in the Serial Monitor.
0@1@?I1@?R1@?[1@?d1@?m1@?v1@?1@?�1@?�1@?�1@?�1@?�1@?�1@?Exception was unhandled.
THIS IS MY CODE FOR THE TRANSMITTER
`//TRANSMITTER
#include <LoRa.h>
#include <SPI.h>
#define ss 5
#define rst 14
#define dio0 2
const int joyLpin = 34; // left joystick
const int joyRpin = 33; // right joystick
while (!Serial);
Serial.println("LoRa Sender");
LoRa.setPins(ss, rst, dio0); //setup LoRa transceiver module
while (!LoRa.begin(433E6)) //433E6 - Asia, 866E6 - Europe, 915E6 - North America
Serial.println(".");
LoRa.setSyncWord(0xA5);
Serial.println("LoRa Initializing OK!");
int joyL = map(analogRead(joyLpin),0,1024,0,255);
int joyR = map(analogRead(joyRpin),0,1024,0,255);
Serial.println("Sending packet: ");
LoRa.beginPacket();
LoRa.print("<");
LoRa.print(joyL);
LoRa.print(",");
LoRa.print(joyR);
LoRa.print(">");
LoRa.endPacket();
delay(50);
THIS IS THE CODE FOR THE RECEIVER
//RECEIVER
#include <LoRa.h>
#include <SPI.h>
#define ss 5
#define rst 14
#define dio0 2
const int motorLfwd = 32; // left motor forward pin
const int motorLbck = 33; // left motor backward pin
const int motorLen = 15; // left motor enable pin
const int motorRfwd = 13; // right motor fwd pin
const int motorRbck = 12; // right motor backward pin
const int motorRen = 25; // right motor enable pin
int deadzone = 20;
int motorLspeed; // left motor speed (0-255 for PWM)
int motorRspeed; // right motor speed (0-255 for PWM)
pinMode(motorLfwd,OUTPUT);
pinMode(motorRfwd,OUTPUT);
pinMode(motorLbck,OUTPUT);
pinMode(motorRbck,OUTPUT);
pinMode(motorLen,OUTPUT);
pinMode(motorRen,OUTPUT);
while (!Serial);
Serial.println("LoRa Receiver");
int packetSize = LoRa.parsePacket(); // try to parse packet
if (packetSize)
Serial.println("Received packet '");
while (LoRa.available()) {
char receivedChar = LoRa.read(); // Read a character from LoRa
if (receivedChar == '<') { // Check if it's the start marker
String dataString = ""; // Create an empty string to store the received data
receivedChar = LoRa.read(); // Read the next character
if (receivedChar == '>') { // Check if it's the end marker
// Extract X and Y values from dataString
int commaIndex = dataString.indexOf(',');
if (commaIndex != -1) { // Check if comma exists in the string
String joyLString = dataString.substring(0, commaIndex); // Extract joyL string
String joyRString = dataString.substring(commaIndex + 1); // Extract joyR string
int joyL = joyLString.toInt(); // Convert joyL string to integer
int joyR = joyRString.toInt(); // Convert joyR string to integer
// Now you have joyL and joyR values
// You can use them for further processing
Serial.print("Received joyL: ");
Serial.print(joyL);
int joyLneutral = 460;
if((joyL-joyLneutral) < -deadzone){ // joystick pushed forward
digitalWrite(motorLfwd,HIGH);
digitalWrite(motorLbck,LOW);
motorLspeed = map(joyL,joyLneutral,0,0,255);
Serial.print(" fwd ");
else if((joyL-joyLneutral) > deadzone){
digitalWrite(motorLfwd,LOW);
digitalWrite(motorLbck,HIGH);
motorLspeed = map(joyL,joyLneutral,1023,0,255);
Serial.print(" back ");
else{
Serial.print(" stop ");
motorLspeed = 0;
Serial.print(motorLspeed);
Serial.print(" Right: ");
Serial.print(joyR);
int joyRneutral = 460;
// set right motor direction and speed
if((joyR-joyRneutral) < -deadzone){ // joystick pushed forward
digitalWrite(motorRfwd,HIGH);
digitalWrite(motorRbck,LOW);
motorRspeed = map(joyR,joyRneutral,0,0,255);
else if((joyR-joyRneutral) > deadzone){
digitalWrite(motorRfwd,LOW);
digitalWrite(motorRbck,HIGH);
motorRspeed = map(joyR,joyRneutral,1023,0,255);
else{
motorRspeed = 0;
Serial.println(motorRspeed);
analogWrite(motorLen,motorLspeed);
analogWrite(motorRen,motorRspeed);
Serial.println(" " + motorRspeed);
Serial.print("Received joyR: ");
Serial.println(joyR);
break; // Exit the inner loop
dataString += receivedChar; // Add the character to dataString
// LoRa.packetRssi();
