I am trying to use an RF transmitter to transmit data when ever the voltage is equal to a certain amount. The only problem is that is transmitting no matter what(even when there is no power)
Here is my code:
#include <RH_ASK.h>
#include <SPI.h> // Not actually used but needed to compile
int analogInput = 1;
float Vout = 0.00;
float Vin = 0.00;
float R1 = 100000.00; // resistance of R1 (100K)
float R2 = 10000.00; // resistance of R2 (10K)
int val = 0;
// Define variable to store the analog value coming from the Sound Sensor
int digitalValue;
RH_ASK driver(2000, 4, 2, 5); // ESP8266 or ESP32: do not use pin 11
void setup(){
pinMode(analogInput, INPUT); //assigning the input port
Serial.begin(9600); //BaudRate
if (!driver.init())
Serial.println("init failed");
void loop(){
val = analogRead(analogInput);//reads the analog input
Vout = (val * 5.00) / 1024.00; // formula for calculating voltage out i.e. V+, here 5.00
Vin = Vout / (R2/(R1+R2)); // formula for calculating voltage in i.e. GND
if (Vin<0.09)//condition
Vin=0.00;//statement to quash undesired reading !
Serial.print("\t Voltage of the given source = ");
Serial.print(Vin);
delay(1000); //for maintaining the speed of the output in serial moniter
if (Vin=30) // When the Sound Sensor sends signla, via voltage present, light LED13 (L)
const char *msg = "hello";
driver.send((uint8_t *)msg, strlen(msg));
driver.waitPacketSent();
Serial.write("sent");
delay(5000);
