I'm using a Nano Sense 33 BLE rev2 board and I would like to send temperature and pression datas through bluetooth connexion to my computer.
Do you have any advice, piece of code or whatever to configure the board and to read datas on the computer ?
Can it be read on serial monitor using bluetooth communication ?
Thanks for your answers.
Regards,
C. Bellessort
What research have you done to accomplish your project. Have you worked out a simple schematic? Have you determined what sensors you will need?
HI,
I read the BT documentation for Arduino BLE and I'm beginning to figure out what should be done.
Actually, there's no sketch for this smal project. I would like to use my nano sense enclosed in a container to verify the Gay-Lussac law P=f(T).
All I need is to receive pressure and temperature from the build-in sensors on my computer via bluetooth.
Regards
It sounds like you are on the correct track. Consider how you will get the information out of the container with the Arduino inside. Look at a sensor that can be outside and connected with a tube such as a Medical Disposable IBP Transducer or a small sensor that will only have a few wires coming out.
