Transmitting numbers
I am usung the HC-12 device to transmit numbers from 2 arrays.
int MyArray1[5] = {1001, 1002, 1003, 1004, 1005};
int MyArray2[5] = {1100, 1200, 1300, 1400, 1500};
Using :
mySerial.println(MyArray2*);*
All numbers in MyArray1 go out, but the number 1500 in MyArray2 does not go out.
I am basically looking for 10 numbers that will transmit okay, is there a reason why this number fails.
Thanks
Yes, there is a very good reason. You have a bug in your code...
Regards,
Ray L.
Thanks Ray, however if I put in one of the other numbers in the slot where 1500 is then that number/position goes out?
I will look again.
The println() method does not take an array (except an array of chars that is NULL terminated).
There's a bug in the code you didn't post.
Did you forget code tags for the code you did post?
Thanks Ray, AWOL, it was a code error. Error in indexes, corrected, all works fine.
More that you didn't actually use the indices at all.
UKHeliBob:
More that you didn’t actually use the indices at all.
They were there - note the italics.
