I have received that from the the serial monitor from the arduino running Shirriff's IR Record example and i want to playback what i received to an arduino then to a IR LED.
Below is what i want to transmit to the IR led. (Would i need to convert it to some other format to transmit?)
ianscott-arduino:
Post the code that collected that data.
Where is that data stored between reception and proposed re-transmission?
What is it going to be transmitted with?
What is it going to be transmitted to?
(and anyall other info that might possibly be relevant.
It got there because the Arduino sent it. No other device or application sends data to the Serial Monitor application. So, you have our permission to store that data in an array or EEPROM or on an SD card INSTEAD of (or in addition to) sending it to the serial port.
