Actually I've done a project i.e. measuring the temperature of the device using TMP36 sensor, I got the output in the serial monitor of the arduino IDE, but I want it on my mobile is this possible? If yes, can you please tell me how?
If you are less than 10m from the Arduino. A bluetooth module may suffice.
If you are on holiday in Acapulco, it probably won't, and a GSM shield is probably in order.
I am using the TMP 36 to read the temperature in a room. The temperature is connected to a gsm module which is connected to an arduino uno . I would like to send a text from my phone to the shield which will trigger the gsm to get data from the temperature sensor and text me back.
Is that possible please? If yes could you help me out with some links to tutorials
