I am currently trying to display two bitmaps on the screen at the same time. My issue is one of the bitmaps is covering the other one. I want to create it so that you can see the image of the bubbles through the tank window.
Sorry I forgot to mention I have bmp images. I am not trying to use png ones. This is just for a reference.
Image 1 Tank
Image 2 Bubbles
Any help would be appreciated
Your display or library does not know how to deal with PNG files most likely
If you use 1 bit black and white images then it does not deal with transparency
You need another buffer where you will do bitwise operations to composite your "transparency" by doing operations at bit/pixel level to decide what's visible or not and then display that calculated buffer
For example initialise your buffer by copying the tank window, overlay one by one the pixels of the bubbles bitmap (possibly with translation if this has to be animated) but only turn on a black pixel in the target buffer if the bubble bitmap pixel is black - don't erase existing black pixels with the white ones from the bubble bitmap
