trasmettere codici telecomando con sendRaw
Con lo sketch IrDump della libreria IrRemote ho ottenuto i seguenti codici, come faccio a trasmetterli con la funzione sendRaw?
E0984BB6
Unknown encoding: E0984BB6 (32 bits)
Raw (24): -8386 1300 -400 1300 -350 450 -1200 1300 -400 1300 -350 450 -1200 450 -1250 450 -1200 1300 -350 450 -1200 500 -1200 450
39D41DC6
Unknown encoding: 39D41DC6 (32 bits)
Raw (24): 16464 1300 -400 1300 -350 450 -1200 1300 -400 1300 -350 450 -1200 450 -1250 1250 -400 450 -1200 450 -1200 500 -1200 450
A32AB931
Unknown encoding: A32AB931 (32 bits)
Raw (24): -30794 1300 -400 1300 -350 450 -1200 1300 -400 1250 -400 450 -1200 450 -1250 450 -1200 450 -1200 450 -1200 500 -1200 1300
143226DB
Unknown encoding: 143226DB (32 bits)
Raw (24): -19326 1300 -350 1300 -350 500 -1200 1300 -350 1300 -350 500 -1200 450 -1200 450 -1200 450 -1250 450 -1200 1300 -350 450
Grazie in anticipo.
e.g.
unsigned int Signal[] = {1300,400,1300,350,450,1200,1300,400,1300,350,450,1200,450,1250,450,1200,1300,350,450,1200,500,1200,450,1000}; //AnalysIR Batch Export - RAW
irsend.sendRaw(Signal, sizeof(Signal)/sizeof(int), 38); //AnalysIR Batch Export - RAW
Cioè praticamente devo togliere tutti i "-" e togliere gli spazi. e mettere tutto dentro ad un array. Dove trovo quel programma "AnalysIR"?
AnalysIR ==> http://bit.ly/191K6cd Email: info@An....IR.com (English or German/Deutsch)
Automatically Generated by AnalysIR - Batch Export Utility
unsigned int Signal_0_0[] = {1300,350,1300,350,500,1200,1300,350,1300,350,500,1200,450,1200,450,1200,450,1250,450,1200,1300,350,450,1000}; //AnalysIR Batch Export - RAW
irsend.sendRaw(Signal_0_0, sizeof(Signal_0_0)/sizeof(int), khz); //AnalysIR Batch Export - RAW
unsigned int Signal_1_1[] = {1300,400,1300,350,450,1200,1300,400,1250,400,450,1200,450,1250,450,1200,450,1200,450,1200,500,1200,1300,1000}; //AnalysIR Batch Export - RAW
irsend.sendRaw(Signal_1_1, sizeof(Signal_1_1)/sizeof(int), khz); //AnalysIR Batch Export - RAW
unsigned int Signal_2_2[] = {1300,400,1300,350,450,1200,1300,400,1300,350,450,1200,450,1250,1250,400,450,1200,450,1200,500,1200,450,1000}; //AnalysIR Batch Export - RAW
irsend.sendRaw(Signal_2_2, sizeof(Signal_2_2)/sizeof(int), khz); //AnalysIR Batch Export - RAW
unsigned int Signal_3_3[] = {1300,400,1300,350,450,1200,1300,400,1300,350,450,1200,450,1250,450,1200,1300,350,450,1200,500,1200,450,1000}; //AnalysIR Batch Export - RAW
irsend.sendRaw(Signal_3_3, sizeof(Signal_3_3)/sizeof(int), khz); //AnalysIR Batch Export - RAW
int khz = 38; (36/40/56......etc)
thanks, but how can I buy AnalysIR if the campaign has expired?
See PM
Ho scritto un articolo sul mio blog, a qualcuno può tornare utile: http://alessandro-riva-elettronica.blogspot.it/2013/10/trasmettere-comando-infrarossi-con.html
