Trembling/Shaking Servo
 Hello Guys I'm really new in working with Arduino and I have a question to you.
 So I actually made a more or less nice project for my knowledge and just have one little but annoying
 problem. I wanted to do 2 little "robot-arms" one with two potmeters which are connected with two
 servos
 on the other arm.The servos should move to the same position as the pots are. But strangely the more
 the
 pots move, the more the servos begin to tremble/shake. I would like to know if I could change this and
 how.
 this is my code btw.
  Controlling two servo positions using two pots (variable resistors)
  by Fernando Meier
#include <Servo.h>
Servo myservo;
Servo myservo2;   //crate two servo object to control two servos
int potpin = 0;
int potpin2 = 2;    // analog pins used to connect the potentiometers
int val;
int val2;    // variables to read the values from the analog pins
  myservo.attach(9);    // attaches the servo on pin 9 to the servo object
  myservo.attach(10);   // attaches the servo on pin 10 to the servo object
  val = analogRead(potpin);            // reads the value of the potentiometer (value between 0 and 1023)
  val = map(val, 0, 1023, 0, 180);     // scale it to use it with the servo (value between 0 and 180)
  myservo.write(val);                  // sets the servo position according to the scaled value
  delay(15);                           // waits for the servo to get there
  val2 = analogRead(potpin2);          // reads the value of the potentiometer (value between 0 and 1023)
  val2 = map(val2, 0, 1023, 0, 180);   // scale it to use it with the servo (value between 0 and 180)
  myservo2.write(val2);                // sets the servo position according to the scaled value
  delay(15)                            // waits for the servo to get there
2Servos_pots.ino (1.31 KB)
Why don’t try this bit of code and share what you see on serial? Could be the pot values are not steady… and of course there is some level of ‘bounce’ as you move the pot knobs
  by Fernando Meier
#include <Servo.h>
Servo myservo;
int potpin = 0;
int val;
  Serial.begin(9600);   //open serial port
  Serial.print("Pot 1 val : ");
  Serial.println(val);
  Serial.println(val2);
You could also try writing to servos only when pot values have changed since last write.
