tri stating a 74hc165 for SPI?
hi everyone
According to the 74hc165 shift register data sheet it can't be directly connected to an SPI bus. I know you can connect a resistor on the output of the 74hc165 or by using a buffer chip like a 74HC125 http://www.taydaelectronics.com/datasheets/A-888.pdf.
What other ways are there?
I was think perhaps to use a opto-coupler, but I'm not sure if an opto-coupler goes into high-Z when not active, i.e. no input?
HC125 is sufficient.
Are you connecting anything else to MISO?
[Are you connecting anything else to MISO?](http://Are you connecting anything else to MISO?)
a clock and perhaps other modules.
[HC125 is sufficient.](http://HC125 is sufficient.)
Gonna have to order some.
another Q:
A HIGH on the 74hc165 output is basically Vcc and a LOW is a direct connection to Ground? So if you just connect the 165 directly to an SPI bus any other module on the bus trying to transmit will create a short circuit?
If you connect the '165 output direct to MISO, yes, it's output will prevent other signals from transmitting correctly when it's output is sitting Hi or Lo. Not a direct short tho, but whatever its output transistors are capable of.
