Trial Cam issues
Hello , Im new to Arduino and i was wondering if someone can help , i can trying to makes a trail cam that gets triggered by a PIR and if another ESP 32 sends the Take Picture command.
Im having a issue where i cant even get the camera to take a picture and save it to the SD card.
Any help would be appreciated
//     Options
#define Delay_For_Next_Snap 10000
#define Debounce_Delay 100
#define EEPROM_SIZE 512  // Define EEPROM size
//     End of options
#include <WiFi.h>
#include <esp_now.h>
#include <SD_MMC.h>
#include <TFT_eSPI.h>
#include "esp_camera.h"
#include <EEPROM.h>  // Read and write from flash memory
// Camera settings for ESP32-CAM
#define CAMERA_MODEL_AI_THINKER
// Manual pin definitions for ESP32-CAM AI-Thinker
#define PWDN_GPIO_NUM  32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM  0
#define SIOD_GPIO_NUM  26
#define SIOC_GPIO_NUM  27
#define Y9_GPIO_NUM    35
#define Y8_GPIO_NUM    34
#define Y7_GPIO_NUM    39
#define Y6_GPIO_NUM    36
#define Y5_GPIO_NUM    21
#define Y4_GPIO_NUM    19
#define Y3_GPIO_NUM    18
#define Y2_GPIO_NUM    5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM  23
#define PCLK_GPIO_NUM  22
int pictureNumber = 0;  // Initialize picture number
// TFT settings
#define TFT_CS 5
#define TFT_RST 16
#define TFT_DC 17
TFT_eSPI tft = TFT_eSPI(); // Instantiate TFT_eSPI object
// Pin definitions
#define PIR_PIN 13
#define PAIR_BUTTON_PIN 12
#define RST_BUTTON_PIN 0 // Define the RST button pin (typically GPIO 0)
#define MAX_DEVICES 20
// Structure to store information about paired devices
typedef struct {
    uint8_t mac[6];
} paired_device;
paired_device pairedDevices[MAX_DEVICES];
int pairedDeviceCount = 0;
// Encryption key
uint8_t encryptionKey[16] = {0x1a, 0x23, 0x45, 0x67, 0x89, 0xab, 0xcd, 0xef, 0xfe, 0xdc, 0xba, 0x98, 0x76, 0x54, 0x32, 0x10};
// ESP-NOW callback
void OnDataRecv(const esp_now_recv_info *recv_info, const uint8_t *data, int len)
    Serial.println("Data received");
    // Trigger picture taking function
    takePicture();
// Function to initialize the camera
void initCamera()
    camera_config_t config;
    config.ledc_channel = LEDC_CHANNEL_0;
    config.ledc_timer = LEDC_TIMER_0;
    config.pin_d0 = Y2_GPIO_NUM;
    config.pin_d1 = Y3_GPIO_NUM;
    config.pin_d2 = Y4_GPIO_NUM;
    config.pin_d3 = Y5_GPIO_NUM;
    config.pin_d4 = Y6_GPIO_NUM;
    config.pin_d5 = Y7_GPIO_NUM;
    config.pin_d6 = Y8_GPIO_NUM;
    config.pin_d7 = Y9_GPIO_NUM;
    config.pin_xclk = XCLK_GPIO_NUM;
    config.pin_pclk = PCLK_GPIO_NUM;
    config.pin_vsync = VSYNC_GPIO_NUM;
    config.pin_href = HREF_GPIO_NUM;
    config.pin_sccb_sda = SIOD_GPIO_NUM;
    config.pin_sccb_scl = SIOC_GPIO_NUM;
    config.pin_pwdn = PWDN_GPIO_NUM;
    config.pin_reset = RESET_GPIO_NUM;
    config.xclk_freq_hz = 20000000;
    config.pixel_format = PIXFORMAT_JPEG;
    // Init with high specs to pre-allocate larger buffers
    if (psramFound()) {
        config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
        config.jpeg_quality = 10;
        config.fb_count = 2;
        config.frame_size = FRAMESIZE_SVGA;
        config.jpeg_quality = 12;
        config.fb_count = 1;
    // Camera init
    esp_err_t err = esp_camera_init(&config);
    if (err != ESP_OK) {
        Serial.printf("Camera init failed with error 0x%x\n", err);
        Serial.println("Check your camera connections and settings.");
// Function to take picture and save to SD card
void takePicture()
    camera_fb_t *fb = esp_camera_fb_get();
    if (!fb) {
        Serial.println("Camera capture failed");
        return;
    // Ensure SD card is mounted before proceeding
    if (!SD_MMC.begin()) {  // Initialize SD card with default pins
        Serial.println("SD Card Mount Failed");
        return;
    // Initialize EEPROM with predefined size
    EEPROM.begin(EEPROM_SIZE);
    pictureNumber = EEPROM.read(0) + 1;
    // Path where new picture will be saved in SD Card
    String path = "/picture" + String(pictureNumber) + ".jpg";
    File file = SD_MMC.open(path.c_str(), FILE_WRITE);
    if (!file) {
        Serial.println("Failed to open file in writing mode");
        file.write(fb->buf, fb->len); // payload (image), payload length
        Serial.printf("Saved file to path: %s\n", path.c_str());
        EEPROM.write(0, pictureNumber);
        EEPROM.commit();
    file.close();
    esp_camera_fb_return(fb);
    // Turns off the ESP32-CAM white on-board LED (flash) connected to GPIO 4
    pinMode(4, OUTPUT);
    digitalWrite(4, LOW);
    gpio_hold_en(GPIO_NUM_4);  // Use gpio_hold_en instead of rtc_gpio_hold_en
    delay(2000);
    Serial.println("Going to sleep now");
    delay(2000);
    esp_deep_sleep_start();
    Serial.println("This will never be printed");
// Interrupt service routine for RST button press
void IRAM_ATTR handleRSTButtonPress()
    takePicture();
// Function to pair new device
void pairNewDevice()
    Serial.println("Pairing new device...");
    // Enable promiscuous mode to listen for pairing requests
    WiFi.scanNetworks(true, true);
    delay(2000); // Wait for scan to complete
    int numNetworks = WiFi.scanComplete();
    for (int i = 0; i < numNetworks; i++) {
        String ssid = WiFi.SSID(i);
        if (ssid.startsWith("ESP32_SENSOR")) {
            uint8_t mac[6];
            WiFi.BSSID(i, mac);
            if (pairedDeviceCount < MAX_DEVICES) {
                memcpy(pairedDevices[pairedDeviceCount].mac, mac, 6);
                esp_now_peer_info_t peerInfo = {};
                memcpy(peerInfo.peer_addr, mac, 6);
                peerInfo.channel = 0;
                peerInfo.encrypt = true;
                memcpy(peerInfo.lmk, encryptionKey, 16);
                if (esp_now_add_peer(&peerInfo) == ESP_OK) {
                    Serial.print("Paired with: ");
                    for (int j = 0; j < 6; j++) {
                        Serial.printf("%02X", mac[j]);
                        if (j < 5) Serial.print(":");
                    pairedDeviceCount++;
                    Serial.println("Failed to add peer");
                Serial.println("Max device limit reached");
    WiFi.scanDelete();
    // Camera initialization
    initCamera();
    // TFT initialization
    tft.init();
    tft.setRotation(1);
    // SD card initialization
        tft.fillScreen(TFT_RED);  // Indicate failure on TFT
        tft.setTextColor(TFT_WHITE, TFT_BLACK);
        tft.drawString("SD Card Mount Failed", 10, 10);
        return;
    uint8_t cardType = SD_MMC.cardType();
    if (cardType == CARD_NONE) {
        Serial.println("No SD Card attached");
        tft.drawString("No SD Card", 10, 10);
        return;
    tft.fillScreen(TFT_BLACK);
    // PIR sensor setup
    pinMode(PIR_PIN, INPUT);
    // Button setup
    pinMode(PAIR_BUTTON_PIN, INPUT_PULLUP);
    // RST button setup
    pinMode(RST_BUTTON_PIN, INPUT_PULLUP);
    // Initialize GPIO ISR service
    static bool isISRServiceInstalled = false;
    if (!isISRServiceInstalled) {
        gpio_install_isr_service(ESP_INTR_FLAG_LEVEL1);
        isISRServiceInstalled = true;
    attachInterrupt(digitalPinToInterrupt(RST_BUTTON_PIN), handleRSTButtonPress, FALLING);
    // ESP-NOW initialization
    WiFi.mode(WIFI_STA);
    if (esp_now_init() != ESP_OK) {
        Serial.println("Error initializing ESP-NOW");
        return;
    esp_now_register_recv_cb(OnDataRecv);  // Register the receive callback
    // Set the encryption key
    if (esp_now_set_pmk(encryptionKey) != ESP_OK) {
        Serial.println("Failed to set encryption key");
        return;
    // Pairing setup
    attachInterrupt(digitalPinToInterrupt(PAIR_BUTTON_PIN), pairNewDevice, FALLING);
    // Initialize EEPROM for picture number storage
    pictureNumber = EEPROM.read(0);
    if (digitalRead(PIR_PIN) == HIGH) {
        delay(Delay_For_Next_Snap);
        takePicture();
    delay(100);
Start with only the code to take a picture and save to SD card, once that works you can add in the other fancy stuff.
The link also has motion detection.
If you take a look at the ESP32CAM schematic here
you will find that those pins are taken by the PSRAM and camera
these pins are taken too, by the SD Card and the camera
Are you using an Arduino Nano ESP32 or another ESP32?
