My intention is to have the arduino connected to the computer which can send ascii messages to it. When the connection has been terminated the arduino will read through the message (under 501 bytes) it's stored and blink the correct pattern for each letter.
Problem is, when the connection is terminated it (the LED I've got in pin1 - the only one of the pins connected as yet) just blinks madly no matter what the message was. If any of you could see where I've been going wrong I'd be very grateful.
One problem with that sketch is that it doesn't wait for the entire message to be received. How do you want to determine when a message is complete? One way would be to detect a special character (such as a carriage return) to indicate the end of message.
Here is some pseudo code assuming you use a carriage return to indicate end of message
// pins and dots would be defined here....
int counter = 0;
int jemmy = 0;
char valerie[501];
void ProcessMessage( int count){
for (int i = 0; i < count; i++){
if (valerie[i] = 'a')
// do your stuff here
loop () {
while (Serial.available() > 0) {
jemmy = Serial.read();
if(jemmy == '\r') { // carriage return??
ProcessMessage( counter); // message received so process it
counter = 0;
valerie[counter++] = jemmy; //add serial data to buffer
This may be more optimization then you want or need, but FWIW here is an idea for handling the conversion of letters to dots. The code uses an array (called monty) that has bits set corresponding to each the 6 pins for each letter. You would need to define all the letters, I did the first few.
I hope the fragment is reasonably clear but feel free to ignore it if it looks like gobbledygook
// array of pin settings for characters 'a' through 'z' (Letter B indicates this is binary representation)
byte monty[] = {B1,B11,B1001,B11001,B10001}; // ToDo: masks needed for chars 'f' through 'z'
void OutDots( byte mask){
// turn the first three dots on if the bit mask is set, turn off of bit mask is 0
digitalWrite(pin1,(mask & 1)); // dot1
digitalWrite(pin2,(mask & 2)); // dot3
digitalWrite(pin3,(mask & 4)); // dot3
delay(10);
digitalWrite(pin1,LOW);
digitalWrite(pin2,LOW);
digitalWrite(pin3,LOW);
delay(70);
// now turn on or off dots 4-6 depending on the mask
digitalWrite(pin1,(mask & 8)); // dot1
digitalWrite(pin2,(mask & 16)); // dot3
digitalWrite(pin3,(mask & 32)); // dot3
delay(10);
delay(110);
char letter = valerie[i];
if( letter >= 'a' && letter <= 'z')
OutDots(monty[letter - 'a' ]) ; // this passes the first entry in monty for 'a', the second for 'b' etc.
; // handle punctuation here
To be honest it does look a little gobbledgookeque, but only because I'd never even seen the language before monday, let alone try to programme in it. I certainly won't be ignoring it though - more learning from it.
Just a few things;
As I understand it this is the C equivelant of Gosub in basic, and the "counter" is the variable which should be carried in to be used within it. Does this mean that only the counter variable can be used within the function? And why the space before "counter"?
So it's a function, but "byte mask"? Similarly,
I understand the concept of masking, but not the syntax. How does it know from that command what segment of code to mask off?
Got a bit lost here. You subtract an 'a' from the letter . . . How does that send the first entry for 'a'?
All terribly newbie questions I'm afraid, but I couldn't find the answers to them on the reference page.
ProcessMessage( counter) > As I understand it this is the C equivelant of Gosub in basic
yes, ProcessMessage is a function, like gosub in basic
right again, the value of counter is passed to the function
no reason, spaces before or after expressions are ignored
void OutDots( byte mask) >So it's a function, but "byte mask"?
This is the declaration of the function OutDots. Outdots takes one parameter, a byte called mask.
that code uses the C bitwise and operator '&'. You may want to have a serch on C bitwise operators on google.
the character 'a' has an ascii value of 97, so subracting 'a' from a lower case letter will give the offset of that latter from 'a'. We want that offset because we use it to look up the mask in our array where 'a' is the first mask, 'b' is the second and so on down the alphabet.
Sorry, I am afraid I threw in way too many arcane aspects of C if this is your first effort.
Ok, I've got the code working (although not fully implementing mem's suggestions yet, due to my lack of confidence with the language), as shown below.
Once hooked up the arduino reads text sent to it until recieves a line feed or carriage return. However, I've been trying to convert the valerie[] value to flash memory so I can expand the length of the string. Couldn't get my head around the http://tinyurl.com/5ntnqm library. Whats the most simple way to do this?
Thanks.
// 8th arduino programme - 9th april 2008
int pin1 = 13;
int pin2 = 12;
int pin3 = 11;
int dot1 = 0;
int dot2 = 0;
int dot3 = 0;
int dot4 = 0;
int dot5 = 0;
int dot6 = 0;
int counter = 0;
int jemmy = 0;
char valerie[501];
serialtomemory();
void serialtomemory() {
if (Serial.available () > 0)
// read the incoming byte:
jemmy = Serial.read ();
// Store it in a character array
valerie[counter] = jemmy;
counter++;
// check if we have over 499 characaters or we recieve a return or line feed
if (counter > 499 || jemmy == 10 || jemmy == 13)
valerie[counter] = 10;
for (; counter < 499; counter ++) {
memorytomechanics();
} // endif
} // endif
} // function end
void memorytomechanics() {
for (counter = 0; counter < 27; counter ++) {
dot1 = 0;
dot2 = 0;
dot3 = 0;
dot4 = 0;
dot5 = 0;
dot6 = 0;
if (valerie[counter] == 'a')
dot1 = 1;
if (valerie[counter] == 'b')
dot1 = 1;
dot2 = 1;
if (valerie[counter] == 'c')
dot1 = 1;
dot4 = 1;
if (valerie[counter] == 'd')
dot1 = 1;
dot4 = 1;
dot5 = 1;
if (valerie[counter] == 'e')
dot1 = 1;
dot5 = 1;
if (valerie[counter] == 'f')
dot1 = 1;
dot2 = 1;
dot4 = 1;
if (valerie[counter] == 'g')
dot1 = 1;
dot2 = 1;
dot4 = 1;
dot5 = 1;
if (valerie[counter] == 'h')
dot1 = 1;
dot2 = 1;
dot5 = 1;
if (valerie[counter] == 'i')
dot2 = 1;
dot4 = 1;
if (valerie[counter] == 'j')
dot2 = 1;
dot4 = 1;
dot5 = 1;
if (valerie[counter] == 'k')
dot1 = 1;
dot3 = 1;
if (valerie[counter] == 'l')
dot1 = 1;
dot2 = 1;
dot3 = 1;
if (valerie[counter] == 'm')
dot1 = 1;
dot3 = 1;
dot4 = 1;
if (valerie[counter] == 'n')
dot1 = 1;
dot3 = 1;
dot4 = 1;
dot5 = 1;
if (valerie[counter] == 'o')
dot1 = 1;
dot3 = 1;
dot5 = 1;
if (valerie[counter] == 'p')
dot1 = 1;
dot2 = 1;
dot3 = 1;
dot4 = 1;
if (valerie[counter] == 'q')
dot1 = 1;
dot2 = 1;
dot3 = 1;
dot4 = 1;
dot5 = 1;
if (valerie[counter] == 'r')
dot1 = 1;
dot2 = 1;
dot3 = 1;
dot5 = 1;
if (valerie[counter] == 's')
dot2 = 1;
dot3 = 1;
dot4 = 1;
if (valerie[counter] == 't')
dot2 = 1;
dot3 = 1;
dot4 = 1;
dot5 = 1;
if (valerie[counter] == 'u')
dot1 = 1;
dot3 = 1;
dot6 = 1;
if (valerie[counter] == 'v')
dot1 = 1;
dot2 = 1;
dot3 = 1;
dot6 = 1;
if (valerie[counter] == 'x')
dot1 = 1;
dot3 = 1;
dot4 = 1;
dot6 = 1;
if (valerie[counter] == 'y')
dot1 = 1;
dot3 = 1;
dot4 = 1;
dot5 = 1;
dot6 = 1;
if (valerie[counter] == 'z')
dot1 = 1;
dot3 = 1;
dot5 = 1;
dot6 = 1;
if (valerie[counter] == 'w')
dot2 = 1;
dot4 = 1;
dot5 = 1;
dot6 = 1;
if (valerie[counter] == '!')
dot2 = 1;
dot3 = 1;
dot5 = 1;
if (valerie[counter] == ',')
dot2 = 1;
if (valerie[counter] == '-')
dot3 = 1;
dot6 = 1;
if (valerie[counter] == '.')
dot2 = 1;
dot5 = 1;
dot6 = 1;
if (valerie[counter] == '?')
dot2 = 1;
dot3 = 1;
dot6 = 1;
if (valerie[counter] == 10)
counter = 0;
return;
Serial.print(valerie[counter]);
if (dot1 == 1)
Serial.print(1);
digitalWrite(13,HIGH);
Serial.print(2);
digitalWrite(13,LOW);
delay(100);
if (dot2 == 1)
Serial.print(1);
Serial.print(2);
delay(100);
if (dot3 == 1)
Serial.print(1);
Serial.print(2);
delay(100);
if (dot4 == 1)
Serial.print(1);
Serial.print(2);
delay(100);
if (dot5 == 1)
Serial.print(1);
Serial.print(2);
delay(100);
if (dot6 == 1)
Serial.print(1);
Serial.println(2);
delay(200);
delay(600);
} // for end
} // function end
prog_char - a signed char (1 byte) -127 to 128
prog_uchar - an unsigned char (1 byte) 0 to 255
Hmm. So are ascii values stored from 0 to 127 on both, or -127 to 0 on the former and 0 to 127 on the latter. Can't see the point of the distinction. Prog_uchar seems the best guess to me.
Writing to flash memory is an unnecessarily complex process. In fact this whole language is unnecessarily complex. Even learning L.in.oleum (anywherebb.com) was a less painful process. Makes me all the more grateful for your help actually.
Here I seem to have got myself into a seemingly idiotic cul de sac. The expression prog_uchar valerie[] PROGMEM = jemmy; produces the error message;
In function 'void serialtomemory()':
error: variable-sized object 'valerie' may not be initialized
Where as when I change it from counter to say, 4, it works. It seems that the flash library doesn't want to mingle intimately with variables from RAM.
// 10th arduino programme - 9th april 2008
#include <avr/pgmspace.h>
int pin1 = 13;
int pin2 = 12;
int pin3 = 11;
int dot1 = 0;
int dot2 = 0;
int dot3 = 0;
int dot4 = 0;
int dot5 = 0;
int dot6 = 0;
int counter = 0;
int jemmy = 0;
PROGMEM prog_uchar valerie[9001];
char crab;
serialtomemory();
counter++;
// . . . and it continues on.
Complex is an understatement. It's because in the processor architecture, program memory is completely separate from data memory. This makes an efficient chip but very ugly for trying to store data in program space.
The example code in the Progmem reference has the strings known at compile time. I have no idea how (or if) the PROGMEM functionality works for strings like yours that are only known at runtime. You may be able to find something in one of the AVR forums but if its possible at all it will not be pretty.
It looks like you have happened to have chosen a project that is much more difficult to implement then one would expect.
I wonder if it will be simpler for you to use some kind of external memory, there are some references to interfacing with SD cards in the playground, for example: http://www.arduino.cc/playground/Code/Dataflash
You can't use PROGMEM for strings that are only known at runtime.*
How big do you want to make the strings? Would a combination of RAM and the on-chip EEPROM be enough? Would a more efficient way of storing the patterns be a possibility?
--Phil.
For those of you reading who can think of a convoluted method involving a custom bootloader, SPM instructions, copied Flash segments and black magic, just keep quiet, we don't want to go there...
I suppose I'm dodging the problem really. In my mostly working code (posted yesterday at 19:02:46), which uses only RAM, I have a string 501 bytes long. Roughly a hundred words. Yet when it's sent a string from the serial port longer than about 25 characters it only outputs the first 25, and then loops itself whenever enter is pressed rather than reset itself as it should. I thought that if I moved it over to flash memory this would somehow change, maybe because there would be more memory available. But if I could get the full 501bytes in ram then that would be sufficient. Otherwise, yes I probably will have to use that dataflash. Arg! More complexity! When I found the arduino I thought it was going to make the whole project so much simpler, and it almost has, almost.
