Trigger 3-pin Ping))) Sensor several times
Good morning,
I have installed the Ping))) sensor on the Arduino Robot (http://arduino.cc/en/Main/Robot). I have adapted the Ping))) code found on the Arduino page to work with the robot. The problem I have is that currently the sensor only checks for one obstacle and afterwards does not turn on again to check for further ones.
Any advice on this, please?
Thank you.
Plenty.
Where?
How?
Which sensor? How are the sensors supposed to turn?
Thank you for your reply. I have attached the code below. I soldered the sensor to pin TKD1. I did not mean that the sensors turn, but rather the robot itself. And I as I said, it does turn, but it gets stuck and just turns all the time, instead of 90 degrees and then checking again.
/* This sketch reads a PING))) ultrasonic rangefinder and returns the
   distance to the closest object in range. To do this, it sends a pulse
   to the sensor to initiate a reading, then listens for a pulse
   to return.  The length of the returning pulse is proportional to
   the distance of the object from the sensor.
   The circuit:
	* +V connection of the PING))) attached to +5V
	* GND connection of the PING))) attached to ground
	* SIG connection of the PING))) attached to digital pin 7
   http://www.arduino.cc/en/Tutorial/Ping
#include <ArduinoRobot.h>
// this constant won't change.  It's the pin number
// of the sensor's output:
int pingPin = TKD1;
  // initialize the Robot, SD card, and display
  Robot.begin();
  Robot.beginTFT();
  Robot.beginSD();
  Robot.displayLogos();
  // draw a face on the LCD screen
  setFace(true);
  // establish variables for duration of the ping,
  // and the distance result in inches and centimeters:
  long duration, inches, cm;
  // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
  // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
  pinMode(pingPin, OUTPUT);
  Robot.digitalWrite(pingPin, LOW);
  delayMicroseconds(2);
  Robot.digitalWrite(pingPin, HIGH);
  delayMicroseconds(5);
  // The same pin is used to read the signal from the PING))): a HIGH
  // pulse whose duration is the time (in microseconds) from the sending
  // of the ping to the reception of its echo off of an object.
  pinMode(pingPin, INPUT);
  duration = pulseIn(pingPin, HIGH);
  // convert the time into a distance
  inches = microsecondsToInches(duration);
  cm = microsecondsToCentimeters(duration);
  // If the robot is blocked, turn until free
  while(cm < 40) {  // If an obstacle is less than 20cm away
    setFace(false); //shows an unhappy face
    Robot.motorsStop(); // stop the motors
    delay(1000); // wait for a moment
    Robot.turn(90); // turn to the right and try again
    setFace(true); // happy face
  // if there are no objects in the way, keep moving
  Robot.motorsWrite(255, 255);
  delay(100);
long microsecondsToInches(long microseconds)
  // According to Parallax's datasheet for the PING))), there are
  // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
  // second).  This gives the distance travelled by the ping, outbound
  // and return, so we divide by 2 to get the distance of the obstacle.
  // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
  return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
// make a happy or sad face
void setFace(boolean onOff) {
  if(onOff) {
    // if true show a happy face
    Robot.background(0, 0, 255);
    Robot.setCursor(44, 60);
    Robot.stroke(0, 255, 0);
    Robot.setTextSize(4);
    Robot.print(":)");
  }else{
    // if false show an upset face
    Robot.background(255, 0, 0);
    Robot.print("X(");
Why not print something to the Serial Monitor, so you can see what is happening?
If you are going to have useless comments, they MUST be right!
Why not replicate the ping code several more times, instead of making a function?
Sorry for the comments, they are still from the source I copied the code from, did not sort them out yet. Will try the printing and give you an update. Thank you so far.
