Trigger relay with Temperature threshold from analoginput?
I have been dabbing with some LM35 temperature sensors and I found a website and code to print the ambient in Celsius:
I would like to trigger a relay when temp exceeds say > 25 Degrees C, any ideas??
Jon.
Code:
float temp;
int tempPin = 0;
temp = analogRead(tempPin);
temp = temp * 0.48828125;
Serial.println(temp);
Very simple. Make an if statement. If your code works as you say it does, something like this would suffice:
if(temp > 25){
The code to control the relay goes in the middle. I'm guessing you would have to give a digitalRead(pin, HIGH) to wherever the relay is?
Cool, thanks Angelo, with your help I compiled this:
====CODE:====
float temp;
int tempPin = 4;
pinMode(7, OUTPUT);
if (temp > 25) {digitalWrite(7, HIGH);
else {
digitalWrite(7, LOW);
======/CODE/=======
IF the temperature exceeds 25 Degrees C it will +5v (HIGH) Digital Pin 7, triggering a relay. When the temperature is below that it will apply 0V.
