Trigger warning as approach gps waypoint
My brother purchased a new boat with swing out racks for wakeboards and skis. Now this is a potential issue when trying to drive into the boat lift as the racks need to be retracted. Is is feasible to have the Adriano poll gps coordinates and trigger a warning when within a certain distance of set coordinates? Obviously it will poll switched on the track and trigger an audio warning. Thanks!
Useful formulas for distance and bearing to waypoints are given here: Calculate distance and bearing between two Latitude/Longitude points using haversine formula in JavaScript
A limitation of the Arduino is that it supports only single-precision floating point calculations. This is not accurate enough for some types of GPS coordinate calculations, but may work well enough in your case.
jremington:
Ok great thanks! Precision is not top priority. Large zone several hundred feet in diameter would be fine.
