I modified users @microbeaut code from his WOKWI-simulation (in short WoSim)
that the code has really self-explaining names and I added comments that shall intensivly explain how it works.
I added switching IO-pin 4 for the 5 millisecond pulses.
The lines that use variable "pulsePinState" (formerly named "Millis" which makes no sense to me at all) can be deleted in the real application.
Same for function with name "printVisualisationToWokwi()"
Arduino Forum
Topics: Triggering 5 millisecond pulses part #1
Category: Using Arduino
SubCategory: Programming Questions
Link: https://forum.arduino.cc/t/triggering-5-millisecond-pulses-part-1/1135999/85
const byte analogInputPin = A0;
const byte pulsePin = 4;
#define compareVoltage 2.0f
#define pulseTime 50ul
#define switchedOn 6
#define switchedOff 1
float input_voltage;
uint32_t pulseStartAtMs;
bool sineCrossedThresholdUpwards; // former name "inPulse";
uint8_t pulsePinState; // former name "Millis";
digitalWrite(pulsePin,LOW);
pinMode(pulsePin, OUTPUT);
input_voltage = 0.0f;
sineCrossedThresholdUpwards = false;
int analog_value = analogRead(analogInputPin);
// assign input_voltage of LAST iteration
float prevInputVoltage = input_voltage; // let's say the value is 1.99V
// as the ACTUAL input_voltage is assigned BELOW prevInputVoltage
// prevInputVoltage holds the voltage of the LAST iteration
input_voltage = (analog_value * 5.0) / 1023.0f; // let's say value is 2.01V
// example-numbers
// 1.99V < 2.00V 2.01V >= 2.00V
if (prevInputVoltage < compareVoltage && input_voltage >= compareVoltage) {
sineCrossedThresholdUpwards = true; // set the flag that indicates what the name says: sineCrossedThresholdUpwards
pulsePinState = switchedOn; // for a real IO-Pin set state = HIGH
digitalWrite(pulsePin,HIGH); // 5 ms-pulse starts
pulseStartAtMs = millis(); // store snapshot of time
// if sinewave is rising
// and crossed threshold check how much time has passed by since threshold-crossing
if (sineCrossedThresholdUpwards && millis() - pulseStartAtMs >= pulseTime) {
// if more time than specified in variable pulseTime HAS passed by
sineCrossedThresholdUpwards = false ; // clear flag that indicates what the name says: sineCrossedThresholdUpwards
pulsePinState = switchedOff;
digitalWrite(pulsePin,LOW); // 5 ms-pulse ends
printVisualisationToWokwi();
void printVisualisationToWokwi() {
// serial printing ONLY used for visualisation in WOKWI
Serial.println(
"Input:= " + String(input_voltage, 2)
+ ", Millis:= " + String(pulsePinState)
+ ", Compare Voltage:= " + String(compareVoltage, 2)
"f" for variabletype float
"ul" for variabletype unsigned long
without the trailing letter the compiler would use variabletype int which could (not must) lead to odd results when calculations are done with the values
