triggering a Arduino pin when water in tank goes below
hello expert's
I am looking to buy some cheap water level sensors for my tank . So would u guys suggest me which one should I buy. Actually I want to trigger a pin when water goes below particular level (I am using solenoid valve to trigger ) So your help Is much appreciated
Thank you and sorry for my bad English
It is same topic here.
https://www.sparkfun.com/products/10221 might be useful
Rubix-Arduino: It is same topic here.
No actually I was asking for water level sensors and I think I need a programming help. sorry I posted in a wrong section
AMPS-N: https://www.sparkfun.com/products/10221 might be useful
That's very costly. Any other sensor whIch will be cheap
If you have chosen already the level sensor gives us data sheet . COde. you need to try ur own as per your logic. If any problem in reading we sort out here.
No one will write program for you
AMPS-N:
No I didn’t decided the level sensors. Is there any cheap sensors ? and yeah I can make the code according to my logic .
water level for Arduino....
http://www.ebay.com.au/itm/Liquid-Water-Level-Sensor-Right-Angle-Float-Switch-PIC-AVR-for-Arduino-/321557626771?pt=LH_DefaultDomain_15&hash=item4ade53ff93
http://www.ebay.com.au/itm/Level-Switches-Liquid-Level-Sensor-Liquid-Plastic-Ball-Float-For-Arduino-/281493772975?pt=LH_DefaultDomain_15&hash=item418a561aaf
bluejets: water level for Arduino....
Thank you very much . Can u pls give me basic programming example of this ?
Your help is much appreciated
www.electroschematics.com/9964/arduino-water-level-indicator-controller/
I think this is the most cheapest method and its easy to go. Is there any problem with this method as I am using solenoid valve so any interference with 5v ? Or possibility of damage to my solenoid valve?
How long is a piece of string?
Show us what ideas you have (circuit diagram) and we may be able to advise you.
Show voltages if you are interfacing with hv solenoids etc.
bluejets: How long is a piece of string?
I don't get you by piece of string ?
Here is the circuit diagram
Photo will not open....anyway, we need a layout of your system to know what you want to do.
You previously ask for detailed help but we have no idea of what you are building.
bluejets: Photo will not open....anyway, we need a layout of your system to know what you want to do.
I used IrfanView to open it and it found an error, but did display to schematic.
Paul
saifkazi: Thank you very much . Can u pls give me basic programming example of this ?
Those ones are just switches - use it just like you'd use any button or switch.
They're basically a toilet float valve, only with a switch instead of a valve - think of it as a toilet valve with a microswitch on the lever.
