Triggering a relay with an sms message
im using a tinysine sim900 gsm board and an arduino uno r3
for about a week now i have been trying different sketches found around the web to control a relay/s via a text message using a sim900 gsm board. Now im pretty new to the programming aspect of things, im just wondering what im doing wrong here.
here is the code im using to try and control 4 relays
#include <SoftwareSerial.h>
#include <SIM900.h>
// EN: String buffer for the GPRS shield message
String msg = String("");
// EN: Set to 1 when the next GPRS shield message will contains the SMS message
int SmsContentFlag = 0;
//control pins of relay.
int relay_a=4;
int relay_b=5;
int relay_c=6;
int relay_d=7;
// EN: Code PIN of the SIM card (if applied)
//String SIM_PIN_CODE = String( "XXXX" );
  Serial.begin(19200);                 // the GPRS baud rate
  // Initialize  PINs
  pinMode( 4, OUTPUT );
  pinMode( 5, OUTPUT );
  pinMode( 6, OUTPUT );
  pinMode( 7, OUTPUT );
  digitalWrite( 4, HIGH );
  digitalWrite( 5, HIGH );
  digitalWrite( 6, HIGH );
  digitalWrite( 7, HIGH );
 Serial.println( "AT+CMGF=1" );
 delay(200);
    char SerialInByte;
    if(Serial.available())
        SerialInByte = (unsigned char)Serial.read();
       delay(5);
        // EN: Program also listen to the GPRS shield message.
       // EN: If the message ends with <CR> then process the message
        if( SerialInByte == 13 ){
          // EN: Store the char into the message buffer
          ProcessGprsMsg();
         if( SerialInByte == 10 ){
            // EN: Skip Line feed
         else {
           // EN: store the current character in the message string buffer
           msg += String(SerialInByte);
// EN: Make action based on the content of the SMS.
//     Notice than SMS content is the result of the processing of several GPRS shield messages.
void ProcessSms( String sms ){
  if( sms.indexOf("ona") >= 0 ){
    digitalWrite( relay_a, LOW );
   if( sms.indexOf("onb") >= 0 ){
    digitalWrite(  relay_b, LOW );
   if( sms.indexOf("onc") >= 0 ){
    digitalWrite(  relay_c, LOW );
  if( sms.indexOf("ond") >= 0 ){
    digitalWrite(  relay_d, LOW );
  if( sms.indexOf("offa") >= 0 ){
    digitalWrite(  relay_a, HIGH );
  if( sms.indexOf("offb") >= 0 ){
    digitalWrite(  relay_b, HIGH );
  if( sms.indexOf("offc") >= 0 ){
    digitalWrite(  relay_c, HIGH );
  if( sms.indexOf("offd") >= 0 ){
    digitalWrite(  relay_d, HIGH );
// EN: Request Text Mode for SMS messaging
void GprsTextModeSMS(){
void GprsReadSmsStore( String SmsStorePos ){
  Serial.print( "AT+CMGR=" );
  Serial.println( SmsStorePos );
// EN: Clear the GPRS shield message buffer
void ClearGprsMsg(){
  msg = "";
// EN: interpret the GPRS shield message and act appropiately
void ProcessGprsMsg() {
  if( msg.indexOf( "Call Ready" ) >= 0 ){
   //  Serial.println( "*** GPRS Shield registered on Mobile Network ***" );
     GprsTextModeSMS();
  // EN: unsolicited message received when getting a SMS message
  if( msg.indexOf( "+CMTI" ) >= 0 ){
   //  Serial.println( "*** SMS Received ***" );
     // EN: Look for the coma in the full message (+CMTI: "SM",6)
     //     In the sample, the SMS is stored at position 6
     int iPos = msg.indexOf( "," );
     String SmsStorePos = msg.substring( iPos+1 );
   //  Serial.print( "SMS stored at " );
  //   Serial.println( SmsStorePos );
     // EN: Ask to read the SMS store
     GprsReadSmsStore( SmsStorePos );
  // EN: SMS store readed through UART (result of GprsReadSmsStore request)
  if( msg.indexOf( "+CMGR:" ) >= 0 ){
    // EN: Next message will contains the BODY of SMS
    SmsContentFlag = 1;
    // EN: Following lines are essentiel to not clear the flag!
    ClearGprsMsg();
    return;
  // EN: +CMGR message just before indicate that the following GRPS Shield message
  //     (this message) will contains the SMS body
  if( SmsContentFlag == 1 ){
 //   Serial.println( "*** SMS MESSAGE CONTENT ***" );
 //   Serial.println( msg );
 //   Serial.println( "*** END OF SMS MESSAGE ***" );
    ProcessSms( msg );
  ClearGprsMsg();
  // EN: Always clear the flag
  SmsContentFlag = 0;
Now with this code loaded to my uno, and everything powered up i get no response what so ever from the relay board, and only "AT+CMGF=1" is displayed in the serial monitor with no OK or anything following.
i don't know if maybe im not doing something else that i need to be doing. does anyone have any code that may work?
the reasons that my outputs are high at startup is because my relay module is a low on relay
any help is greatly appreciated.
Steve
