Triggering Mosfets with IR Sensors
Can these IR sensors trigger a MOSFET gate directly? or do they have to run through an arduino?
sensors to use:
Mosfets:
Thanks!
PRobably. Are you wanting to turn the MOSFET on or off?
They should work. The MOSFET datasheet indicates it is a logic level MOSFET (Vgs = 5V). The product description for the sensors indicate it can be driven by 5V and the output can drive a relay which means it can drive this logic level MOSFET.
I would like to turn 2 Leds off and 1 Led on. A combination of N channel and P channels.
You don't need a MOSFET to drive and LED. MOSFETs are for high current/power applications. LEDs do not fall into that category (unless you are using strings of leds). Any transistor will work for driving 3 LEDs.
