Hi guys, I'm super new to arduino and but have had a lot of fun making a system to replace my old gate controller which died.
I've just put a magnetic compass sensor in my driveway to measure deflection in degrees caused by a large metal object (a car) so the gate automatically opens, has a delay, and then closes.
The unit is also operated with RF button thingos. Everything is working just fine and dandy, but I worry that if the compass shifts the gate will go into a constant open/close situation and possibly burn out the 240v motor.
What I would like to do is measure if it opens more then 5 times in 30 minutes via pin 6 (The mag sensor) that it writes in a section of code that stops it working.
if (digitalRead(6) == HIGH && digitalRead(gc) == HIGH && digitalRead(go) == LOW)
{ // OPEN WITH AUTO SHUT from mag sensor, SETS AUTO CLOSE HIGH TO AVOID BEING MIXED UP WITH GENERAL STOPPING
autoclose = HIGH;
Wire.beginTransmission(I2C_ADDR);
Wire.write(0x12);
Wire.write(1);
Wire.endTransmission();
delay(2000); // DELAY TO ENSURE GATE PASSES LIMITS, ALSO STOPS BOUNCE
is what I'm doing at the moment, it sets autoclose high so then my auto close code can deal with it differently then just when the buttons are pressed. I want to incorporate the same thing in the trigger code like
if (digitalRead(6) == HIGH && digitalRead(gc) == HIGH && digitalRead(go) == LOW) && Notfaulty == LOW)
I want to use a millis timer to set the NotFaulty variable to high if the gate opens 5 time in 30minutes, therefore stopping the loop which may destroy the motor.
Is anyone able to help me get my head around this? I really have no idea
Sorry if that's long winded and ass about face. Full code below.
#include "Wire.h" // for I2C bus
#define I2C_ADDR 0x20
int button2 = 5; // Button 2 on controller
int button = 2; // Button 1 on controller
int gc = 3; // Gate closed
int go = 4; // Gate open
static int autoclose;
autoclose = LOW;
Wire.begin(); // Wake up I2C bus
// Set I/O bank A to outputs
Wire.write(0x00);
Wire.write(0x00);
if (digitalRead(button2) == HIGH && digitalRead(gc) == HIGH && digitalRead(go) == LOW)
{ // OPEN WITH AUTO SHUT, SETS AUTOCLOSE HIGH TO AVOID BEING MIXED UP WITH GENERAL STOPPING
autoclose = HIGH;
Wire.write(0x12);
Wire.write(1);
if (digitalRead(button) == HIGH && digitalRead(gc) == HIGH && digitalRead(go) == LOW)
{ // OPEN CODE
Wire.write(0x12);
Wire.write(1);
if (digitalRead(button) == HIGH && digitalRead(gc) == LOW && digitalRead(go) == HIGH)
{ // CLOSE CODE
Wire.write(0x12);
Wire.write(2);
if (digitalRead(gc) == HIGH && autoclose == LOW) // STOP WHEN CLOSED LIMIT IS HIT
{ Wire.beginTransmission(I2C_ADDR);
Wire.write(0x12);
Wire.write(0);
delay(2000);
if (digitalRead(go) == HIGH && autoclose == LOW) // STOP WHEN OPEN LIMIT IS HIT
Wire.write(0x12);
Wire.write(0);
delay(2000);
if (digitalRead(go) == HIGH && autoclose == HIGH) // STOP WHEN OPEN LIMIT IS HIT WITH DELAY
Wire.write(0x12);
Wire.write(0);
delay(300000); // DELAY FOR GATE TO STAY OPEN
autoclose = LOW;
Wire.write(0x12);
Wire.write(2); // START CLOSING AFTER DELAY
delay(2000);
// breakkkkkkkkkkkkkkkkkkkkklowkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk mag sensor trigger code below
autoclose = HIGH;
Wire.write(0x12);
Wire.write(1);
and there's a seperate arduino on the mag controller running pin 13 high if the heading changes
HMC5883L Triple Axis Digital Compass. Compass Example.
Read more: http://www.jarzebski.pl/arduino/czujniki-i-sensory/3-osiowy-magnetometr-hmc5883l.html
GIT: https://github.com/jarzebski/Arduino-HMC5883L
Web: http://www.jarzebski.pl
(c) 2014 by Korneliusz Jarzebski
#include <Wire.h>
#include <HMC5883L.h>
HMC5883L compass;
pinMode(13, OUTPUT);
// Initialize Initialize HMC5883L
Serial.println("Initialize HMC5883L");
while (!compass.begin())
Serial.println("Could not find a valid HMC5883L sensor, check wiring!");
// Set measurement range
compass.setRange(HMC5883L_RANGE_1_3GA);
// Set measurement mode
compass.setMeasurementMode(HMC5883L_CONTINOUS);
// Set data rate
compass.setDataRate(HMC5883L_DATARATE_30HZ);
// Set number of samples averaged
compass.setSamples(HMC5883L_SAMPLES_8);
// Set calibration offset. See HMC5883L_calibration.ino
compass.setOffset(0, 0);
Vector norm = compass.readNormalize();
// Calculate heading
float heading = atan2(norm.YAxis, norm.XAxis);
// Set declination angle on your location and fix heading
// You can find your declination on: http://magnetic-declination.com/
// (+) Positive or (-) for negative
// For Bytom / Poland declination angle is 4'26E (positive)
// Formula: (deg + (min / 60.0)) / (180 / M_PI);
float declinationAngle = (4.0 + (26.0 / 60.0)) / (180 / M_PI);
heading += declinationAngle;
// Correct for heading < 0deg and heading > 360deg
if (heading < 0)
heading += 2 * PI;
if (heading > 2 * PI)
heading -= 2 * PI;
// Convert to degrees
float headingDegrees = heading * 180/M_PI;
// Output
Serial.print(" Heading = ");
Serial.print(heading);
Serial.print(" Degress = ");
Serial.print(headingDegrees);
delay(100);
digitalWrite(13, LOW);
if (headingDegrees < 10)
{ (digitalWrite(13, LOW));
}else
(digitalWrite(13, HIGH));
