Sorry for the delay. I confirm that the arduino will receive spaces. Lets say _ is a space. The arduino may receive: 'ID_Restrict_=_255CRLF' The idea is I want to remove the spaces, then use sRX.startsWith and parse the string so I end up with the value 255 that I convert to an int and store.
I understand I can load an array of chars and will look into this way of receiving serial data but I would still like to understand why the trim function does not work in my code.
From what I've read, it should be quite straight forward and sRX.Trim(); should get rid of the spaces. But it does not.
Thanks for the help.
Here is my complete code:
#include <stdio.h> // for function sprintf
// Declare variables to be used in the software
String sTemp; // sTemp is a temporary string used to convert different types into a string and later used to store the RX data
String sRX; // sRX is used to store the received data from the serial port
// Following integers are for storing values
int iAutoSet;
int iBaudRate;
int iBrightness;
int iButtons;
int iFade;
int iFadeSpeed;
int iFlickerRed;
int iIDRestrict;
int iImageFreeze;
int iInfraRed;
int iKeyLevel;
int iKeyer;
int iLocked;
int iMode;
int iOverscan;
int iOutHCenter;
int iOutHWidth;
int iOutVCenter;
int iOutVHeight;
int iPanXPos;
int iPanYPos;
int iReset;
int iRGBTerm;
int iRS232ID;
int iSCPhase;
int iSense;
int iSignalType;
int iStoreSettings;
int iSound;
int iSyncOut;
int iTotalLines;
int iVertFreq;
int iVGABot;
int iVGALeft;
int iVGAStore;
int iVGATop;
int iVGAWidth;
int iVideoStd;
int iZoom;
// Configuring the arduino
// Open the serial port
Serial.begin(9600); // open the serial port to send
// data back to the computer at
// 9600 bits per second
Serial.setTimeout(10); //set a timeout so the arduino does wait for too long on the serial.readstring
//Initialize values with ramdom numbers to emulate stored settings
iAutoSet = (random(0, 2)); //Auto Set Value 0 or 1
iBaudRate = (random(0, 192));
iBrightness = (random(0, 251));
iButtons = (random(0, 2));
iFade = (random(0, 2));
iFadeSpeed = (random(0, 26));
iFlickerRed = (random(0, 2));
iIDRestrict = (random(0, 256));
iImageFreeze = (random(0, 2));
iInfraRed = (random(0, 2));
iKeyLevel = (random(0, 251));
iKeyer = (random(0, 5));
iLocked = (random(0, 2));
iMode = (random(0, 5));
iOverscan = (random(0, 2));
iOutHCenter = (random(0, 641));
iOutHWidth = (random(0, 641));
iOutVCenter = (random(0, 577));
iOutVHeight = (random(0, 577));
iPanXPos = (random(0, 641));
iPanYPos = (random(0, 577));
iReset = (random(0, 2));
iRGBTerm = (random(0, 2));
iRS232ID = (random(0, 256));
iSCPhase = (random(-12, +13));
iSense = (random(0, 4));
iSignalType = (random(0, 2));
iSound = (random(0, 2));
iStoreSettings = (random(0, 2));
iSyncOut = (random(0, 2));
iTotalLines = (random(0, 641));
iVertFreq = (random(40, 70));
iVGABot = (random(0, 641));
iVGALeft = (random(0, 641));
iVGAStore = (random(0, 641));
iVGATop = (random(0, 641));
iVGAWidth = (random(0, 641));
iVideoStd = (random(0, 2));
iZoom = (random(0, 2));
// Welcome message
Serial.println(" TVone Emulator Ver 1.0");
Serial.println(" 10th August 2017");
Serial.println("This code is used to emulate the TVone board in order to test software");
Serial.println(" developed in Delphi. ");
// This function gets rid of any character that is not part of the number and returns an integer corresponding to the value sent in the command
int GetValue(String myString)
int iStart = myString.indexOf('=')+1; // Get the position of the = symbol
String s = myString.substring(iStart); // Keep only the characters in between
s.replace("/r"," "); // Replace any carriage return with white space
s.replace("/n"," "); // Replace any line feed with white space
s.trim(); // Get rid of all white spaces
return s.toInt(); // Convert the string into an integer and return the value
// This function processes the string command and sends the appropriate output
String GetOutput(String myString, int *myInt) {
if (sRX.indexOf('=') == -1) //If '=' is not present then it is a query for value
return String(*myInt); //Return the value from the pointer
else //Else its a command change the value
*myInt = GetValue(myString); // get the value and store it to the pointed integer
return ">"; //Return acknowledge expected to be sent if successfull
// Software that runs in a non-stop loop
sRX = Serial.readString(); // Read from the serial port and put the values in the string sRX
sRX.trim(); //get rid of any white spaces
// Check which command is received and process accordingly
if(sRX.startsWith("Auto")) sTemp = GetOutput(sRX,&iAutoSet); // If the string starts with "Auto" then process get output and point to iAutoset
else if(sRX.startsWith("Baud")) sTemp = GetOutput(sRX,&iBaudRate);
else if(sRX.startsWith("Brig")) sTemp = GetOutput(sRX,&iBrightness);
else if(sRX.startsWith("Butt")) sTemp = GetOutput(sRX,&iButtons);
else if(sRX.startsWith("Fade S")) sTemp = GetOutput(sRX,&iFadeSpeed); //FadeS must be before Fade else Fade would always be true for both conditions
else if(sRX.startsWith("Fade")) sTemp = GetOutput(sRX,&iFade);
else if(sRX.startsWith("Flic")) sTemp = GetOutput(sRX,&iFlickerRed);
else if(sRX.startsWith("ID Re")) sTemp = GetOutput(sRX,&iIDRestrict);
else if(sRX.startsWith("Imag")) sTemp = GetOutput(sRX,&iImageFreeze);
else if(sRX.startsWith("Infr")) sTemp = GetOutput(sRX,&iInfraRed);
else if(sRX.startsWith("Key L")) sTemp = GetOutput(sRX,&iKeyLevel);
else if(sRX.startsWith("Keye")) sTemp = GetOutput(sRX,&iKeyer);
else if(sRX.startsWith("Lock")) sTemp = GetOutput(sRX,&iLocked);
else if(sRX.startsWith("Mode")) sTemp = GetOutput(sRX,&iMode);
else if(sRX.startsWith("Over")) sTemp = GetOutput(sRX,&iOverscan);
else if(sRX.startsWith("Out H-C")) sTemp = GetOutput(sRX,&iOutHCenter);
else if(sRX.startsWith("Out H-W")) sTemp = GetOutput(sRX,&iOutHWidth);
else if(sRX.startsWith("Out V-C")) sTemp = GetOutput(sRX,&iOutVCenter);
else if(sRX.startsWith("Out V-H")) sTemp = GetOutput(sRX,&iOutVHeight);
else if(sRX.startsWith("Pan X")) sTemp = GetOutput(sRX,&iPanXPos);
else if(sRX.startsWith("Pan Y")) sTemp = GetOutput(sRX,&iPanYPos);
else if(sRX.startsWith("Rese")) sTemp = GetOutput(sRX,&iReset);
else if(sRX.startsWith("RGB T")) sTemp = GetOutput(sRX,&iRGBTerm);
else if(sRX.startsWith("RS23")) sTemp = GetOutput(sRX,&iRS232ID);
else if(sRX.startsWith("SC Ph")) sTemp = GetOutput(sRX,&iSCPhase);
else if(sRX.startsWith("Sens")) sTemp = GetOutput(sRX,&iSense);
else if(sRX.startsWith("Sign")) sTemp = GetOutput(sRX,&iSignalType);
else if(sRX.startsWith("Soun")) sTemp = GetOutput(sRX,&iSound);
else if(sRX.startsWith("Stor")) sTemp = GetOutput(sRX,&iStoreSettings);
else if(sRX.startsWith("Sync")) sTemp = GetOutput(sRX,&iSyncOut);
else if(sRX.startsWith("Tota")) sTemp = GetOutput(sRX,&iTotalLines);
else if(sRX.startsWith("Vert")) sTemp = GetOutput(sRX,&iVertFreq);
else if(sRX.startsWith("VGA B")) sTemp = GetOutput(sRX,&iVGABot);
else if(sRX.startsWith("VGA L")) sTemp = GetOutput(sRX,&iVGALeft);
else if(sRX.startsWith("VGA S")) sTemp = GetOutput(sRX,&iVGAStore);
else if(sRX.startsWith("VGA T")) sTemp = GetOutput(sRX,&iVGATop);
else if(sRX.startsWith("VGA W")) sTemp = GetOutput(sRX,&iVGAWidth);
else if(sRX.startsWith("Vide")) sTemp = GetOutput(sRX,&iVideoStd);
else if(sRX.startsWith("Zoom")) sTemp = GetOutput(sRX,&iZoom);
else sTemp = "?"; // If nothing matches then send "?"
if (sRX != "") Serial.println(sTemp); // Transmit the completed sTemp out of the arduino
} //end of the loop, start again at the top of void loop()
