Hello, fisrts of all is that I am Spanish, so my english could be quite poor.
My problem is that I can't upload my codes to my Adafruit Trinket 5V. I have installed all the drivers from Adafruit but is impossible, t gives me error mensage, and the same when I try to repair it ussing my Genuino Uno Board.
Has someone had the same problems, what am I doing bad?
Thanks.
The erros Message:
Arduino:1.8.2 (Windows 10), Tarjeta:"Adafruit Trinket 8MHz"
D:_Programas Instalados_\ARDUINO\libraries\Servo\src\avr\Servo.cpp: In function 'void __vector_3()':
D:_Programas Instalados_\ARDUINO\libraries\Servo\src\avr\Servo.cpp:82:44: error: cannot convert 'volatile uint8_t* {aka volatile unsigned char*}' to 'volatile uint16_t* {aka volatile unsigned int*}' for argument '2' to 'void handle_interrupts(timer16_Sequence_t, volatile uint16_t*, volatile uint16_t*)'
handle_interrupts(_timer1, &TCNT1, &OCR1A);
D:_Programas Instalados_\ARDUINO\libraries\Servo\src\avr\Servo.cpp: In function 'void initISR(timer16_Sequence_t)':
D:_Programas Instalados_\ARDUINO\libraries\Servo\src\avr\Servo.cpp:129:5: error: 'TCCR1B' was not declared in this scope
TCCR1B = _BV(CS11); // set prescaler of 8
D:_Programas Instalados_\ARDUINO\libraries\Servo\src\avr\Servo.cpp:136:5: error: 'TIFR1' was not declared in this scope
TIFR1 |= _BV(OCF1A); // clear any pending interrupts;
D:_Programas Instalados_\ARDUINO\libraries\Servo\src\avr\Servo.cpp:137:5: error: 'TIMSK1' was not declared in this scope
TIMSK1 |= _BV(OCIE1A) ; // enable the output compare interrupt
exit status 1
Error compilando para la tarjeta Adafruit Trinket 8MHz.Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
