trio motor code error
hey everyone, I have to make my own design for school. Me and my friend thought about a submarine, so he designed it and I should write the code, however this isn’t the easiest part. I can’t make a code myself, so I search for a code on internet. I found one at this site:https://howtomechatronics.com/tutorials/arduino/arduino-dc-motor-control-tutorial-l298n-pwm-h-bridge/ . It was very helpful, so credits to the guy who made it, but he uses only two motors. We use three motors(two for forward, backward and sides; motor AB, and one for up and down; motor C). so I have to write a code myself. I tried it, but when I did the verify check he gave my some errors. I don’t know what to do right now so maybe you can help me. I would be really grateful.
here’s the code by the way
  #define enA 9
  #define in1 4
  #define in2 5
  #define enB 10
  #define in3 6
  #define in4 7
  #define enC 11
  #define in5 2
  #define in6 3
  int motorSpeedA = 0;
  int motorSpeedB = 0;
  int motorSpeedC = 0;
    pinMode(enA, OUTPUT);
    pinMode(enB, OUTPUT);
    pinMode(in1, OUTPUT);
    pinMode(in2, OUTPUT);
    pinMode(in3, OUTPUT);
    pinMode(in4, OUTPUT);
    pinMode(in5, OUTPUT);
    pinMode(in6, OUTPUT);
    int xAxis = analogRead(A0); // Read Joysticks X-axis
    int yAxis = analogRead(A1); // Read Joysticks Y-axis
    int zAxis = analogRead(A2); // Read Joysticks Z-axis
    analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
    analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
    analogWrite(enC, motorSpeedC); // Send PWM signal to motor C
    // Y-axis used for forward and backward control
    if (yAxis < 470) {
      // Set Motor A backward
      digitalWrite(in1, HIGH);
      digitalWrite(in2, LOW);
      // Set Motor B backward
      digitalWrite(in3, HIGH);
      digitalWrite(in4, LOW);
      // Convert the declining Y-axis readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
      motorSpeedA = map(yAxis, 470, 0, 0, 255);
      motorSpeedB = map(yAxis, 470, 0, 0, 255);
    else if (yAxis > 550) {
      // Set Motor A forward
      digitalWrite(in1, LOW);
      digitalWrite(in2, HIGH);
      // Set Motor B forward
      digitalWrite(in3, LOW);
      digitalWrite(in4, HIGH);
      // Convert the increasing Y-axis readings for going forward from 550 to 1023 into 0 to 255 value for the PWM signal for increasing the motor speed
      motorSpeedA = map(yAxis, 550, 1023, 0, 255);
      motorSpeedB = map(yAxis, 550, 1023, 0, 255);
    // If joystick stays in middle the motors are not moving
    else {
      motorSpeedA = 0;
      motorSpeedB = 0;
    // X-axis used for left and right control
    if (xAxis < 470) {
      // Convert the declining X-axis readings from 470 to 0 into increasing 0 to 255 value
      int xMapped = map(xAxis, 470, 0, 0, 255);
      // Move to left - decrease left motor speed, increase right motor speed
      motorSpeedA = motorSpeedA - xMapped;
      motorSpeedB = motorSpeedB + xMapped;
      // Confine the range from 0 to 255
      if (motorSpeedA < 0) {
        motorSpeedA = 0;
      if (motorSpeedB > 255) {
        motorSpeedB = 255;
    if (xAxis > 550) {
      // Convert the increasing X-axis readings from 550 to 1023 into 0 to 255 value
      int xMapped = map(xAxis, 550, 1023, 0, 255);
      // Move right - decrease right motor speed, increase left motor speed
      motorSpeedA = motorSpeedA + xMapped;
      motorSpeedB = motorSpeedB - xMapped;
      if (motorSpeedA > 255) {
        motorSpeedA = 255;
      if (motorSpeedB < 0) {
        motorSpeedB = 0;
      // Z-axis used for forward and backward control
      if (zAxis < 470) {
        // Set Motor c backward
        digitalWrite(in5, HIGH);
        digitalWrite(in6, LOW);
        // Convert the declining Z-axis readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
        motorSpeedC = map(zAxis, 470, 0, 0, 255);
      else if (zAxis > 550) {
        // Set Motor C forward
        digitalWrite(in5, LOW);
        digitalWrite(in6, HIGH);
        motorSpeedC = map(zAxis, 550, 1023, 0, 255);
      // If joystick stays in middle the motor is not moving
      else {
        motorSpeedC = 0;
and here are the errors:
Compiling sketch...
/tmp/990517735/MSS_113_motorABC/MSS_113_motorABC.ino: In function 'void loop()':
/tmp/990517735/MSS_113_motorABC/MSS_113_motorABC.ino:116:7: error: expected '}' at end of input
exit status 1
Please go back and edit your post to use code tags for the code.
And please post the "some errors" you got (in code tags). When I verify what you posted the only error I get is missing } at the end.
What Arduino are you compiling it for?
Steve
arduino uno
And have you tried adding a couple of } at the end of input like it suggests?
Checking for balanced brackets {} and () is one of the first things you should do. You must always have the same number of openers { as closers }.
Steve
