Trip relay(s) when a device is discovered on LAN
I’ve been researching this a lot over the last couple of days and i’m surprised that I haven’t found a solution. I keep ending up on labby.co.uk but it seems the project has been removed.
I am looking for code to trip two relays when a phone is connected to the local network which will open a garage door one to provide power and the other to activate the switch. (the garage door opens on its own if it is left plugged in)
I know that this has been done before however each project that I’ve found has since been abandoned and I have not been able to get it to work properly. I would think this project would be popular within the home automation realm so I am hoping to be pointed in the right direction.
I’m using Arduino Uno with an Ethernet shield.
-Respectfully, allthenamesweretaken
Maybe this topic isn’t as popular as I thought it would be.
Here is the code that I’ve come up with in case anyone is interested. PM me if you need support.
#include <Dhcp.h>
#include <Dns.h>
#include <Ethernet.h>
#include <EthernetClient.h>
#include <EthernetServer.h>
#include <EthernetUdp.h>
/* YourDuino Example: Relay Control 1.10
Handles “Relay is active-low” to assure
no relay activation from reset until
application is ready.
terry@yourduino.com /
-----( Import needed libraries )-----/
-----( Declare Constants )-----/
#define RELAY_ON 0
#define RELAY_OFF 1
-----( Declare objects )-----/
-----( Declare Variables )-----/
#define Relay_1 2 // Arduino Digital I/O pin number
#define Relay_2 3
Ping Example
This example sends an ICMP pings every 500 milliseconds, sends the human-readable
result over the serial port.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 30 Sep 2010
by Blake Foster
#include <SPI.h>
#include <ICMPPing.h>
#include <Twitter.h>
Twitter twitter(“xxxxxxxxxxxxxxxxxxxxx”);
char aopen[] = “Garage door open!”;
char aclosed[] = “Garage door closed!”;
-----( Declare Variables )-----*/
#define Relay_2 3
byte mac = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; // max address for ethernet shield
byte ip = {10,0,0,6}; // ip address for ethernet shield
IPAddress pingAddr(10,0,0,72); // ip address to ping
SOCKET pingSocket = 0;
char buffer [256];
ICMPPing ping(pingSocket, (uint16_t)random(0, 255));
//-------( Initialize Pins so relays are inactive at reset)----
digitalWrite(Relay_1, RELAY_OFF);
digitalWrite(Relay_2, RELAY_OFF);
//—( THEN set pins as outputs )----
pinMode(Relay_1, OUTPUT);
pinMode(Relay_2, OUTPUT);
delay(500); //Check that all relays are inactive at Reset
// start Ethernet
Ethernet.begin(mac, ip);
ICMPEchoReply echoReply = ping(pingAddr, 4);
if (echoReply.status == SUCCESS)
sprintf(buffer,
“Reply 1[%d] from: %d.%d.%d.%d: bytes=%d time=%ldms TTL=%d”,
echoReply.data.seq,
echoReply.addr[0],
echoReply.addr[1],
echoReply.addr[2],
echoReply.addr[3],
REQ_DATASIZE,
millis() - echoReply.data.time,
echoReply.ttl);
sprintf(buffer, “Echo request failed1; %d”, echoReply.status);
delay(250);
// After ping is unsuccessful (phone offline) check again so that the garage door cycles only when the phone is first
//offline then online so that it doesn’t continue the open/close cycle during the entire time the phone is online
sprintf(buffer,
“Reply[%d] from: %d.%d.%d.%d: bytes=%d time=%ldms TTL=%d”,
echoReply.data.seq,
echoReply.addr[0],
echoReply.addr[1],
echoReply.addr[2],
echoReply.addr[3],
REQ_DATASIZE,
echoReply.ttl);
digitalWrite(Relay_1, RELAY_ON);// turn on power
delay(500); //wait for a 1/2 second
digitalWrite(Relay_2, RELAY_ON);// press button to open
digitalWrite(Relay_2, RELAY_OFF);// depress button to open door
delay(500); //wait 180 seconds to open door
digitalWrite(Relay_2, RELAY_ON);// press button to close
digitalWrite(Relay_2, RELAY_OFF);// depress button to close
// wait for a second
digitalWrite(Relay_1, RELAY_OFF);// kill power
sprintf(buffer, “Echo request failed2; %d”, echoReply.status);
Serial.println(buffer);
