Hi, I'm trying to make a GPS based solar tracker and want to use the hour angle at sunrise to trigger the tracker. This is what I've got till now:
#include <Dusk2Dawn.h>
#include <Servo.h>
#include <DS1307RTC.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
Servo servo1; //controls altitude
int Mins=0,Lastmin=0;
int lon, lat, diff,i,r,s,y,m,d;
SoftwareSerial mySerial(3, 2);
Adafruit_GPS GPS(&mySerial);
//conversion of degrees and minutes to decimal degrees
double convertDegMinToDecDeg (float degMin)
double min = 0.0;
double decDeg = 0.0;
min = fmod((double)degMin, 100.0);
degMin = (int) ( degMin / 100 );
decDeg = degMin + ( min / 60 );
return decDeg;
GPS.begin(9600);
tmElements_t tm;// specific time from RTC is initialized
tm.Minute ;
tm.Hour ;
tm.Day ;
tm.Month ;
tm.Year ;
time_t s_date = makeTime(tm);
y = GPS.year;
m = GPS.month;
d = GPS.day;
lon = convertDegMinToDecDeg(GPS.longitude);
lat= convertDegMinToDecDeg(GPS.latitude);
float diff = 5.30;
//calculation of sunrise and sunset as per data from GPS
Dusk2Dawn place(lon, lat, diff);
int placeSunrise = place.sunrise(y, m, d, false);
int placeSunset = place.sunset(y, m , d, false);
char time1[6];
Dusk2Dawn::min2str(time1, placeSunrise);
Serial.println(time1);
char time2[6];
Dusk2Dawn::min2str(time2, placeSunset);
Serial.println(time2);
placeSunrise = r;
placeSunset = s;
servo1.attach(4);
servo1.write(180);
tmElements_t tm;
for (i=r; i<=s ; i+=5)
if(RTC.read(tm))
//controlled movement of motor and panel
Mins = tm.Minute;
//9 am to 9:20 am
if(Mins==200) servo1.write(5);
if(Mins==220) servo1.write(10);
if(Mins==240) servo1.write(15);
if(Mins==260) servo1.write(20);
if(Mins==280) servo1.write(25);
if(Mins==300) servo1.write(30);
if(Mins==320) servo1.write(35);
if(Mins==340) servo1.write(40);
if(Mins==360) servo1.write(45);
if(Mins==380) servo1.write(50);
if(Mins==400) servo1.write(55);
if(Mins==420) servo1.write(60);
if(Mins==440) servo1.write(65);
if(Mins==460) servo1.write(70);
if(Mins==480) servo1.write(75);
if(Mins==500) servo1.write(80);
if(Mins==520) servo1.write(85);
if(Mins==540) servo1.write(90);
//3 am to 3:20 am
if(i=s)
servo1.write(0);//move back to initial position
The Dusk2Dawn library is the one found here
I'm trying to include the hourAngleSunrise function in my setup and assign it to 'hour',to use in the loop.
I checked the .h file and it shows hourAngleSunrise is in the private part of the class; would that affect being able to add it in?
Any suggestions on how I can go about this are appreciated.
