i have tried the following
with the IDE toos select UNO, then burn bootloader
the ide says Burning bootloader to i/o board (this may take a minute)
stays there seems like forever and have waited several minutes and appears nothing happens
try # 2
use AVR Studio 6.0
i am able to program the UNO using ATmegaBOOT_168_atmega328.hex
i set fuses to
extended FD
High D6
Low FF
which are the same as the orginal UNO
and set lockbit to CF which is also the same as orginal UNO
results
when i try to upload sketh i get the not in sync error wih board selected UNO
if i change board to duemilanova then i can upload sketch 1 time but can not upload again
any ideas what i can do
as a side note the bootloader shipped with arduino is not the same as preloaded on UNO
Connect your AVRips MKii equivalent to the PC.
Put your blank ATmega328P chip in the Arduino UNO.
Connect the six-pin cable from the AVRisp to the six-pin header on the right end of the Arduino UNO, making sure Pin 1 is aligned.
Select Tools->Programmers->AVRisp MKII
Select Tools->Boards->Arduino UNO
Select Tols->Burn Bootloader
Does it work when you do that? If not, what error do you get?
Actually waited 30 minutes
was basically thinking if it got screwed up somehow, bricked, wrong fuses set, put in the wrong place and pins get shashed or broken off, sometime people do things in the filed they are note supposed to do.
once my initial testing is done i will be booting a modifued TFTP bootloaded that has the watchdog timer stuff in it so I can send a softwere reset over the network to reset and wait the required time for a TFTP upload to beign so i can remotely update my code (hope it works) then i wont care about the orginal bootloader
