Trouble Combining 2 Sketches
Good Morning All,
I'm trying to make a simple code for a child's night light using:
WS2812 LED Strips (2 strips of 10 LED's)
Simple 2 Pole Push Button
3 Pole Sound Sensor
Nano Board.
Ultimately I'd like to expand the program to several different options but at present I'm trying to combine a simple solid color pattern and a music reactive code
I've used the basic button code (included below) to cycle through 5 color options with no problem and I've used the music reactive code (Included below) with no problem. It's when I combine the 2 coded that things go south...I get a solid color that does not respond to music and can not cycle through the 2 programs.
I know the wiring and set up works because I can run each seperate sketch on the night light and get expected results so I'm assuming code issue and given my level of inexperience I'm hoping for something simple that I'm leaving out...
CODE FOR SIMPLE PUSH BUTTON 2 OPTIONS:
#include <FastLED.h>
#include <OneButton.h>
#define NUM_LEDS_PER_STRIP 10
#define BTN_PIN 10
CRGB firstleds[NUM_LEDS_PER_STRIP];
CRGB secondleds[NUM_LEDS_PER_STRIP];
uint8_t patternCounter = 0;
uint8_t hue = 0;
// Push button connected between pin 7 and GND (no resistor required)
OneButton btn = OneButton(BTN_PIN, true, true);
  FastLED.addLeds<WS2812B, 4>(firstleds, NUM_LEDS_PER_STRIP);
  FastLED.addLeds<WS2812B, 6>(secondleds, NUM_LEDS_PER_STRIP);
  FastLED.setBrightness(100);
  btn.attachClick(nextPattern);
  switch (patternCounter) {
    case 0:
      Rainbow();
    case 1:
      ColorFade();
  FastLED.show();
  btn.tick();
void nextPattern() {
  patternCounter = (patternCounter + 1) % 2;  // Change the number after the % to the number of patterns you have
//------- Put your patterns below -------//
void Rainbow() {
  for (int i = 0; i < NUM_LEDS_PER_STRIP; i++) {
    firstleds[i] = CHSV(hue + (i * 10), 255, 255);
    secondleds[i] = CHSV(hue + (i * 10), 255, 255);
  EVERY_N_MILLISECONDS(50) {
    hue++;
void ColorFade() {
    firstleds[i] = CHSV(hue, 255, 255);
    secondleds[i] = CHSV(hue, 255, 255);
  EVERY_N_MILLISECONDS(200) {
    hue++;
CODE FOR SIMPLE MUSIC REACTIVE STRIP
#include <FastLED.h>           // https://github.com/FastLED/FastLED
#define NUM_LEDS_PER_STRIP 10  // Number of LEDs
#define SENSITIVITY 300        // Ranges from 0 to 1023
#define MAX_BRIGHTNESS 200     // Ranges from 0 to 255
#define SOUND_PIN A0           // Connect sound detector to this pin
#define SATURATION 150         // Ranges from 0 to 255
#define MINVAL 60
#define HUE_INIT 10
#define HUE_CHANGE 1
byte brightness[NUM_LEDS_PER_STRIP];
byte hue[NUM_LEDS_PER_STRIP];
int analogVal;
int DELAY;
  pinMode(SOUND_PIN, INPUT);
  for (int i = 0; i <= NUM_LEDS_PER_STRIP; i++) {
    brightness[i] = 0;
    hue[i] = 0;
  //Turn off all the LEDs
    firstleds[i] = CRGB::Black;
    secondleds[i] = CRGB::Black;
  //Update the LED strip
  FastLED.show();
  analogVal = analogRead(SOUND_PIN);
  if (analogVal > SENSITIVITY)
    analogVal = SENSITIVITY;
  if (analogVal < MINVAL)
    analogVal = 0;
  - 5 styles for sound reactive led strip are given below in different lines.
  - Uncomment the function which you want to try and comment the others.
  - "LinearFlowing" is uncommented by default.
  LinearFlowing();
  // LinearReactive();
  // BrightnessReactive();
  //CentreProgressive();
  // EdgeProgressive();
  FastLED.show();
void LinearFlowing() {
  byte val = map(analogVal, 0, SENSITIVITY + 1, 0, MAX_BRIGHTNESS);
  DELAY = map(analogVal, 0, SENSITIVITY + 1, 20, 1);
    brightness[NUM_LEDS_PER_STRIP - i] = brightness[NUM_LEDS_PER_STRIP - i - 1];
    hue[NUM_LEDS_PER_STRIP - i] = hue[NUM_LEDS_PER_STRIP - i - 1];
  brightness[0] = val;
  byte hue = HUE_INIT;
    firstleds[i] = CHSV(hue += HUE_CHANGE, SATURATION, brightness[i]);
    secondleds[i] = CHSV(hue += HUE_CHANGE, SATURATION, brightness[i]);
  delay(DELAY);
MY ATTEMPT TO COMBINE THE 2 CODES:
#define BTN_PIN 10
#define MINVAL 60
#define HUE_INIT 10
int analogVal;
int DELAY;
    brightness[i] = 0;
    hue[i] = 0;
  FastLED.show();
    case 0:
      LinearFlowing();
    case 1:
      BlueLight();
  FastLED.show();
  btn.tick();
    analogVal = 0;
  delay(DELAY);
void BlueLight() {
    firstleds[i] = CHSV(160, 128, 255);
    secondleds[i] = CHSV(160, 128, 255);
  FastLED.show();
I've tried to search for information on line to correct this but I'm getting confused with the options from multiple sources. Does anyone have a suggestion for a good onliine reference for basic arduino coding/problem solving. (I have about 4 bookmarked in my computer but it gets confusing).
Given that the individual programs work as expected on the project I have not included a mock up of the wiring but can if needed.
Thanks in advance for help.
Living dangerously
The color-changing code counts up in the for-loop until i < NUM_LEDS_PER_STRIP is no longer true
and this is correct. arrays start counting at zero and this means the highest index-number is NUM_LEDS_PER_STRIP minus 1
example 10 LEDs.
10 - 1 = 9
count from 0 to 9 (which is ten elements)
the other code counts up to
which means the 10 is included
but an array starting at index 0 that goes up to 10 has 11 elements
which means the code writes data to a place that belongs to something else and the code or some variable get corrupted
Not sure if this is the bug. But it is something that should be corrected
best regards Stefan
