I am trying to make a simple sketch that just reads data from the ADIS16355 IMU. I am using the new Teensy 3.0. I am using USB for power. The IMU is using the same 5V power, and all the other connections to it should be 3.3V since that’s the operating voltage of the Teensy 3.0.
These are all the connections:
Teensy 3.0 pin 10 (CS0) to ADIS16355 pin 6 (CS)
Teensy 3.0 pin 11 (DOUT) to ADIS16355 pin 15 (DIN)
Teensy 3.0 pin 12 (DIN) to ADIS16355 pin 4 (DOUT)
Teensy 3.0 pin 13 (SCK) to ADIS16355 pin 3 (SCK)
Teensy 3.0 pin 25 (AGND) to ADIS16355 pin 13 (GND)
Teensy 3.0 pin 26 (Vin) to ADIS16355 pin 11 (VCC)
The loop function of my sketch just prints the XACCL_OUT value every 5 ms. Unfortunately the output is just:
Z Accel (g): 0.00
Z Accel (g): 0.00
…ad infinitum
Here is the code that handles the SPI stuff: (EDIT: Replaced with working code for posterity)
// Copyright 2012 Jacob Niehus
// jacob.niehus@gmail.com
// Do not distribute without permission.
#include "ADIS16355_Interface.h"
#include <Streaming.h>
// Pin definitions
const int SSpin = 10;
// SPI address definitions (upper; // lower)
const uint8_t SUPPLY_OUT = 0x03; // 0x02
const uint8_t XGYRO_OUT = 0x05; // 0x04
const uint8_t YGYRO_OUT = 0x07; // 0x06
const uint8_t ZGYRO_OUT = 0x09; // 0x08
const uint8_t XACCL_OUT = 0x0B; // 0x0A
const uint8_t YACCL_OUT = 0x0D; // 0x0C
const uint8_t ZACCL_OUT = 0x0F; // 0x0E
const uint8_t XTEMP_OUT = 0x11; // 0x10
const uint8_t YTEMP_OUT = 0x13; // 0x12
const uint8_t ZTEMP_OUT = 0x15; // 0x14
const uint8_t AUX_ADC = 0x17; // 0x16
// LSB definitions
const float SUPPLY_LSB = 0.0018315; // V per LSB
const float GYRO_LSB = 0.07326; // deg/sec per LSB (300 deg/sec dynamic range)
const float ACCL_LSB = 0.002522; // g per LSB
const float AUX_ADC_LSB = 0.0006105; // V per LSB
// Other constants
const int T_DATA_STALL_MICROSEC = 15;
void ADIS16355::Initialize()
pinMode(SSpin, OUTPUT);
Deselect();
SPI.begin();
SPI.setBitOrder(MSBFIRST);
SPI.setClockDivider(SPI_CLOCK_DIV32);
SPI.setDataMode(SPI_MODE3);
float ADIS16355::getXaccel()
uint16_t data = readRegister(XACCL_OUT);
int16_t dataLSBs = twosComplementToInt(data, 14);
return dataLSBs * ACCL_LSB;
float ADIS16355::getYaccel()
uint16_t data = readRegister(YACCL_OUT);
float ADIS16355::getZaccel()
uint16_t data = readRegister(ZACCL_OUT);
uint16_t ADIS16355::readRegister(uint8_t address)
uint8_t upper, lower;
// First data frame sends address in bits 8-13
Select();
SPI.transfer(address);
SPI.transfer(0);
Deselect();
// Second data frame receives upper then lower bytes of data
Select();
upper = SPI.transfer(0);
lower = SPI.transfer(0);
Deselect();
if ((upper & (1 << 6)) == 1)
Serial << "WARNING: Error/alarm accessing address " << address << endl;
if ((upper & (1 << 7)) == 1)
Serial << "WARNING: Using old data from address " << address << endl;
// Combine upper and lower bytes to form output
return (upper << 8) | lower;
void ADIS16355::writeRegister(uint8_t address, uint8_t value)
// Turn on left-most bit to give a write command
uint8_t command = address | 1 << 7;
Select();
// Transfer R/W command and register first,
// followed by the value to be written
SPI.transfer(command);
SPI.transfer(value);
Deselect();
int16_t ADIS16355::twosComplementToInt(uint16_t data, uint8_t bits)
if ((data & (1 << (bits - 1))) == 0)
for (uint8_t iter = bits; iter < 16; iter++)
data &= ~(1 << iter);
return (int16_t)data;
data = ~data + 1;
return -(int16_t)data;
void ADIS16355::Select()
digitalWrite(SSpin, LOW);
void ADIS16355::Deselect()
digitalWrite(SSpin, HIGH);
delayMicroseconds(T_DATA_STALL_MICROSEC);
You can download the full sketch here: http://dropcanvas.com/4ujy7
Datasheet for the IMU is here: http://www.analog.com/static/imported-files/data_sheets/ADIS16350_16355.pdf
The SCK pin is the pin connected to the LED pin built into the Teensy 3.0. The LED doesn’t seem to light up at all, and it seems like it should appear to be at half-brightness since it turns on and off quickly. I don’t have an oscilloscope or logic analyzer, though this may be what finally forces me to get one.
I tried putting some print statements in the readAddress function to print the values stored in “upper” and “lower” and they are always zero.
Can anyone take a look at the code and let me know if I’m doing something obviously wrong?
