Trouble compiling for my MicroServo SG90
Hey, I'm running an Arduino UNO on 1.0.5 and am trying to load up Sweep sketch for my servo to no avail. And this is directly opening the code from Examplebook.
I get a compiling error of
" 'Servo' does not name a type "
here is the CODE
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
and here is my compiling result
Sweep:8: error: 'Servo' does not name a type
Sweep.ino: In function 'void setup()':
Sweep:15: error: 'myservo' was not declared in this scope
Sweep.ino: In function 'void loop()':
Sweep:23: error: 'myservo' was not declared in this scope
Sweep:28: error: 'myservo' was not declared in this scope
I'm under the impression that the the compiling wont be affected by whether or not I have the servo plugged in, is that wrong? But I tried both plugged in and not. I suspect it's an issue with my libraries, but I am not sure how to tell.
Thanks for any leads.
Yikes- gonna repost this in an appropriate board. I'll try to delete asap!
Try adding this right after your include statement:
Servo myservo;
