Hello, I am having difficulty configuring and communicating 2 Xbee series1 modules, while using the XCTU software.
Current set-up is as follows:
2x XBee Series 1 (802.15.4) modules
1x Uno R3 Board
1x XBee Explorer USB Dongle
1x Sparkfun XBee Shield
XCTU Software Version 6.3.5
One XBee is plugged into the XBee Shield, which is plugged into the Uno. The other XBee is plugged into the Explorer Dongle. Both the Dongle and the Uno are plugged into USB ports on my computer.
Problem: I open the XCTU software and click the "Discover Radio Modules" button. The software recognizes the XBee on the Dongle, but does not recognize the XBee attached to the Shield & Uno.
Things I have tried:
- Removing the Uno's ATmega chip before attempting to discover the XBee using XCTU.
- No Change.
- Switching the XBee modules.
- No Change, the one on the Dongle is recognized, the one on the shield is not.
- Putting a jumper wire between the reset pin and the ground pin on the Uno.
- No Change.
- Selecting all USB/Serial Port Parameters (baud rates, parity, etc) when discovering radio modules.
- No Change.
Using a new and alternative XBee shield for the Uno.
-No Change. -
Communicating between devices without XCTU configuration per Arduino's instructions, and utilizing an extra Uno and XBee shield.
- I didn't understand the instructions to "put both jumpers on the shield to the 'USB' setting", and "Switch the jumpers to the Xbee setting". Ignoring those instructions, the XBees failed to communicate with each other.
- Configuring devices with an older version of XCTU (I don't know what version it is, and it doesn't say).
- No Change.
Question:
How the heck do I setup my XBee & Arduino & Shield so that the XCTU software recognizes it?
Please, if you can offer any insight into how I might be able to get these XBee shields working, I would be super glad to hear it. Thank you!
