I have the agent installed but the icon is still gray colored when it is resumed and on. I am unable to connect to the cloud to upload sketches to my Arduino. Is there any way to fix this?
Are you running macOS Ventura? If so when they rolled this out it blocked the agent. I uninstalled and re-installed the agent and when I installed it I had to open security settings and give it permission.
I am running Windows 10 and I made an exception in my Avast antivirus and it still didn't work
You might be misinterpreting the color. There is still some information out there that says the Arduino Create Agent's icon should be blue/green when active. The color was changed to white in 2020:
This is how the icon looks on Windows when the agent is running:
https://raw.githubusercontent.com/arduino/arduino-create-agent/main/icon/icon_win.ico
This is how it looks on Windows when the agent is paused:
https://raw.githubusercontent.com/arduino/arduino-create-agent/main/icon/icon_win_hiber.ico
Note that there is not a lot of difference between the white color of the active icon and the light gray of the paused icon (even less so when they are on the colored background of your system tray.
So as long as it is white rather than gray, then the icon color is not indicating any problem.
I'm not sure I understood correctly what you mean by this. Please provide a more detailed description to help me to understand it.
If you are encountering any error or warning messages, please provide the full and exact text of those messages.
That makes sense, I do believe that the color is correct on mine. However I still do not get the proper connection because when I try to upload a script to my Arduino it does not work
I am running into the same sort of issue. MacOS Ventura is reporting that the installation package is corrupted and asks if I want to move it to the trash or cancel the installation. Either choice does not allow me to install. There are also issues with the certificate installation failing. I can provide screenshots if needed.
-John
Hi @linerider. I'm sorry for the trouble with Arduino Create Agent and macOS Ventura. Please check this Arduino Help Center article on the subject:
If you have any questions or problems while following those instructions, let me know and I'll see if I can help out.
Followed those instructions with the same results yesterday with the same results.
-John
I have screenshots of the whole process but need a place to send them.
-John
You have been promoted to "Trust Level 1" with the Arduino forum software, so you can now attach the screenshots to forum posts without any restrictions.
You can add the screenshot to a reply here by doing any one of the following:
- Press Ctrl+V to paste the screenshot from the clipboard.
- Save the screenshot as an image and then drag and drop it into a forum reply.
- Save the screenshot as an image, click the upload button (
) in the post composer toolbar, and then select the image file.
Is there any progress on this issue? I am paying for the web based capability and cannot use it due to your broken agent.
-John
Hi @linerider. I think there have been some updates to the tutorial since the last time we discussed it. Please try it again:
That worked.
-John
I'm glad it is working now.
Regards,
Per
