Trouble Controlling Pong Paddles using Bluetooth Serial Module
In case anyone else in the future needs to figure this out I was able to solve the original problem of controlling paddles for a pong game using a bluetooth serial module using the following code:
I included the following at the top of the program
 #include <SoftwareSerial.h>
int incomingP1Byte = 0;   // variable to store serial data
int paddle1Val = 0;
int paddle2Val = 0;
int flag = 0;
SoftwareSerial player1Serial(2, 3); // Initialize SoftwareSerial (RX, TX) for the bluetooth connections
Then accessed the paddles with the following code in void loop()
	if(player1Serial.available() > 0)
	  incomingP1Byte = player1Serial.read();
		Serial.print("I received: ");
		Serial.println(incomingP1Byte);
		// delay 10 milliseconds to allow serial update time
		delay(10);
	  flag=0;
	//check incoming byte for direction
	if (incomingP1Byte == 49)
		player1Serial.println(paddle1Val--);
		delay(10);
	else if (incomingP1Byte == 50)
		player1Serial.println(paddle1Val++);
		delay(10);
		//-------------------------------right paddle
		else if (incomingP1Byte == 51)
		player1Serial.println(paddle2Val--);
		delay(10);
		 else if (incomingP1Byte == 52)
		player1Serial.println(paddle2Val++);
		delay(10);
	// if the byte is equal to "1", make the left paddle go up
	if (incomingP1Byte == 1)
Here's a hint. 1 != '"1". 1 != '1', either.
