Hi Everyone and thanks for stopping by!
I´ve bought an Arduino UNO Rev3 and a Seeed Studio Grove 125KHz RFID Reader (uem4100 Card).
I figured out how to set up the Card Reader and I´ve got a Program Reading RFID Dongles in Mode UART und another Programm for Reading the same dongles in WIEGAND Mode. - When changing the Programm you also need to set a Jumper on the Board, which I also Did.
On my RFID Dongles I have there is a 10 Digit Number writen. If I User the Reader which came with the dongles under windows in Texteditor, it writes the 10 Digit Number (including Trailing Zeros and LineFeed/CR)
The Dongles I have are 125 kHz EM4100 ISO14443A Dongles.
When Reading UART I found out that the Transfered String is HEX and I need to Calculate 5th to 10th Digit to get the exact 10 Digit Number writen on the Dongle.
However when reading the WIEGAND String, I can´t figure out how to Translate/ Convert it.
This is my Result for 5 Dongles:
Dongle 1
Aufschrift 0001217496
Scan with UART 01001293D858
Convert Hex to DEC Hex: 1293D8 --> DEC: 1217496
Scan W26 01101111101101011011000010Dongle 2
Aufschrift 0001217485
Scan with UART 01001293CD4D
Convert Hex to DEC Hex:1293CD --> DEC: 1217485
Scan W26 01110111101101011011000011Dongle 3
Aufschrift 0013477100
Scan with UART 0100CDA4EC84
Convert Hex to DEC Hex:CDA4EC --> DEC: 13477100
Scan W26 00101000110010010110110001Dongle 4
Aufschrift 0013477183
Scan with UART 0100CDA53F56
Convert Hex to DEC Hex:CDA53F --> DEC: 13477183
Scan W26 00110000110010010110101100Dongle 5
Aufschrift 0014594826
Scan with UART 2900DEB30A4E
Convert Hex to DEC Hex:DEB30A --> DEC: 14594826
Scan W26 00000000100001010011001111
The RFID-Reader gives this hints, but still I can´t figure out how it Works.
Starting with ParityBits Even and Odd.
Counting the 1 in First and Second PArt including the PB:
1111011010110 1100001001110 = 9 & 6
1111011010110 1100001100101 = 9 & 6
0001100100101 1010110000000 = 5 & 4
Without PB:
1 111011010110 8 110000100111 0 5
1 111011010110 8 110000110010 1 5
0 001100100101 4 101011000000 0 3
as you can see, this isn´t consistent or I´m do something wrong.
I´m actually Fine with Using UART, but for interest and because I know for Entry-Control-Systems Wiegand is the Standard, i would love to know the solution to this Riddle. Thinking about it for 2 days now I hope to get some help her.
Here is the ProgrammCode for UART:
link between the computer and the SoftSerial Shield
at 9600 bps 8-N-1
Computer is connected to Hardware UART
SoftSerial Shield is connected to the Software UART:D2&D3
#include <SoftwareSerial.h>
SoftwareSerial SoftSerial(2, 3);
unsigned char buffer[64]; // buffer array for data receive over serial port - No Difference if Length is 1 or 64 or 256? (Changed here and in Line 28
int count = 0; // counter for buffer array
SoftSerial.begin(9600); // the SoftSerial baud rate
Serial.begin(9600); // the Serial port of Arduino baud rate.
// if date is coming from software serial port ==> data is coming from SoftSerial shield
if (SoftSerial.available())
while(SoftSerial.available()) // reading data into char array
buffer[count++] = SoftSerial.read(); // writing data into array
if(count == 64)break;
Serial.write(buffer, count); // if no data transmission ends, write buffer to hardware serial port
clearBufferArray(); // call clearBufferArray function to clear the stored data from the array
count = 0; // set counter of while loop to zero
if (Serial.available()) // if data is available on hardware serial port ==> data is coming from PC or notebook
SoftSerial.write(Serial.read()); // write it to the SoftSerial shield
void clearBufferArray() // function to clear buffer array
// clear all index of array with command NULL
for (int i=0; i<count; i++)
buffer[i]=NULL;
Even that it´s working you see in my Comment that i can give buffer almost every size and it´s still working. This is something i don´t get, but as seen above, i´m able to translate to the given 10 digit number which is written on the dongle.
And here´s the Wiegand Code:
// RFID_Wiegand_INT.pde to read card ID number from the RFID with
// wiegand interface.
// see http://www.seeedstudio.com/depot/ for details on 125K RFID module
// ... [Copyright and license information]
// Global variables
byte RFIDcardNum[4]; // Not used in this version
unsigned long cardValue = 0; // Variable to store the card value
int bitCount = 0; // Counter for the number of received bits
// Set up the interrupt pins, attach the interrupt routines
pinMode(2, INPUT_PULLUP); // Set up pin 2 as input with internal pull-up
pinMode(3, INPUT_PULLUP); // Set up pin 3 as input with internal pull-up
attachInterrupt(digitalPinToInterrupt(2), ISRreceiveData0, FALLING);
attachInterrupt(digitalPinToInterrupt(3), ISRreceiveData1, FALLING);
// If all bits have been received, process the data
if (bitCount == 26) {
// The card data is ready to be processed
// You may implement parity check here
// Print the card value in binary format
Serial.print("Card Value (Binary): ");
for (int i = 25; i >= 0; i--) {
Serial.print((cardValue >> i) & 1);
// Reset for next read
bitCount = 0;
cardValue = 0;
// ISR for Data0 (representing bit '0')
void ISRreceiveData0() {
if (bitCount < 26) {
cardValue <<= 1; // Shift the earlier bits
bitCount++;
// ISR for Data1 (representing bit '1')
void ISRreceiveData1() {
cardValue |= 1; // Add '1' to the LSB of cardValue
bitCount++;
thanks and best regards
Richard
